Just picked my 4motion up tonight and the ESP light is on permanent
Been reading up on this and looks expensive ! Read another thread saying that if the steering wheel is not straight when the wheels are then this could be the cause!
My steering wheel isn't centered so could this be the fault?
Could possibly be. ESP faults are quite common, mind.
My 4 motion had the ESP light on too, I replaced the sensors behind the dash and did the steering wheel angle sensor reset but the light stayed on.
 I searched the internet for a solution and found that the ESP can be coded out leaving the ABS to work as it should.
 Here is a LINK to coding out the ESP with VCDS.
Reset the codes and see which ones come back.
 Steering angle sensor, this will need checking to see if it sends a signal, if it does then a simple reset of that can be done, I did mine with the steering wheel off, wheels facing straight and turned the sensor wheel until a zero was present on the VCDS software, sorted it out.
Locking module I wouldn't worry about.
65535 error can be displayed in many areas, it is present on my car showing a Haldex issue, however everything works fine, here is an explanation from Ross Tech.
http://wiki.ross-tech.com/wiki/index.php/65535
There will be nothing wrong with your sensor, when you strip the column down and take your steering wheel off you can make the sensor turn with your finger, hooked up the VCDS you can turn it until it shows zero, refit everything and you have sorted the issue.
 Or you can do it this way http://www.r32oc.com/topic/76146-mk4-steering-angle-sensor-g85-fixed/
