Hello,
i have a problem with my mk3 and this since the day of acquisition... (Engine type AAA / 1992)
If i connect the battery for the first time, the engine run immediately, but after the first start, when i want to start again, I have to operate the starter for 3 to 5 seconds before the engine starts  :(
i bougth a scanner U281, and after analysis, "no error" or "linking error", i tried to use VAG-COM but i can't to read in the ECU...
i tested the ignition during the starter activation, and it's ok...
Can you help me ?
Thanks
I thought to the ignition barrel, because, if i move a little bit, the power turn off...
i will replace these 2 parts, and see the results.
it is possible to change the diagnostic connection to connect it directly to the ECU ?
Unscrew front plate of dash and see the port.
(Where fan dials are etc).
See all wires intact. Or ask someone with a Vagcom set up near you to see if your port will work or not. May have been software you were using as i know few do not read or connect up.
Think your heading the right way with the ign barrel.
