CraigArcade 0 Posted April 26, 2015 Report Share Posted April 26, 2015 Hi I'm having fun with my vr6 electrics. I drove to the shops a few days ago and when I got in the car to drive home I had a no crank no start issue but I managed to bump start it. Since the I have done the following.. Bypassed immobiliser which meant it cranked over but had no fuel or spark. So I spent a day removing the entire laser line immobiliser from my car but still no fuel no spark. But because the car still bumps starts I thought maybe it's a live to the ecu so luckily my brother has the same car. Tried my ecu in his car to find it cranks but no fuel/spark. Tried his ecu in my car to find it cranks but no fuel/spark. What should I try next? because if its the ignition switch surely my ecu should have worked in his car. It still bump starts fineAny suggestions would be immensely appreciated cheers Link to post Share on other sites
brummy_h 4 Posted April 26, 2015 Report Share Posted April 26, 2015 sounds like you ignition switch try bridging the wires Link to post Share on other sites
CraigArcade 0 Posted April 27, 2015 Author Report Share Posted April 27, 2015 problem solved. it was my ignition switch cheersi managed to wire a start button to by-pass the ignition switch untill i fit a new one Link to post Share on other sites
edwards0359 7 Posted May 17, 2015 Report Share Posted May 17, 2015 Sorry to bring up an old thread but how did you manage to wire the start switch in? This sounds exactly like a problem that I'm having!! Thanks, Jack. Link to post Share on other sites
