Finally got my rear beam back on with the new bits, but unsure how the brake lines were routed. It's the lines that run along the passanger side of the car in to the bottom two unions on the brake compensator. Do they go straight into the compensator or are they routed around the body? Any help?:)
That would be perfect mate. Ye it's the copper lines that go into the brake compensator. Dunno if they just go straight from the body of the car into the compensator or follows the bottom of the car.. Pics would clear it up. Cheers:)
That's exactly what I needed mate. Much appreciated!! I would definitely have a look at the compensator if you've lowered your car. Unsure how to go about it as I haven't set mine up yet but will look into it and see what I can find out:) thanks again!
