VR6DEN 53 Posted May 9, 2015 Report Share Posted May 9, 2015 (edited) Hi All,This is driving me INSANE I change my brake set up to bigger brakes and calipers.After bleeding all the brakes the pedal on first hits the floor with an air escaping sound then second and third pump get hard.Keeps losing air.....but there is no fluid leaks.Please anyone knows what is the cure ?Thanks,Den. Edited May 9, 2015 by VR6DEN Link to post Share on other sites
Airone 16 Posted May 9, 2015 Report Share Posted May 9, 2015 Upgrade master cylinder, callipers need more fluid than the cylinder can provide... Link to post Share on other sites
VR6DEN 53 Posted May 10, 2015 Author Report Share Posted May 10, 2015 As I upgraded to mk1 audi tt 312mm calipers will an audi tt master cylinder fit and due the job? Thanks Den Link to post Share on other sites
ssaunders 199 Posted May 11, 2015 Report Share Posted May 11, 2015 Hi, if yours were 288's then the 312's should use the same caliper (maybe a mm smaller) for the change i thought you just need to swap carriers and add a spacer plate.eurocarparts show the same part no's for the 1.8 tt(225) and the VR6 master cylinders so you shouldnt need it changed (unless faulty)good lucksteve Link to post Share on other sites
VR6DEN 53 Posted May 11, 2015 Author Report Share Posted May 11, 2015 Thanks for this Link to post Share on other sites
VR6DEN 53 Posted May 14, 2015 Author Report Share Posted May 14, 2015 All fixed.....WHAT A BUNCH OF COWBOYS Bealieboy 1 Link to post Share on other sites
ssaunders 199 Posted May 14, 2015 Report Share Posted May 14, 2015 All fixed.....WHAT A BUNCH OF COWBOYS Me or everyone else? Link to post Share on other sites
VR6DEN 53 Posted May 14, 2015 Author Report Share Posted May 14, 2015 No the monkeys that worked on my car! Link to post Share on other sites
