steveFC 0 Posted May 15, 2015 Report Share Posted May 15, 2015 Hi all, I am looking for someone to replace my heater matrix on a 97 Highline,, Not sure if this the done thing on here to post for jobs, but if anyone is willing & very able (i.e done a few b4) , please do get in touch before i go down the garage route. Cheers steve Link to post Share on other sites
oliver cox 71 Posted May 15, 2015 Report Share Posted May 15, 2015 i am a mechanic never done a matrix on that model but done loads on other cars Link to post Share on other sites
steveFC 0 Posted May 15, 2015 Author Report Share Posted May 15, 2015 Hi,, think Manchester prob a bit too much of an ask,, and i really want someone who has done this job pref a few times (although i am sure u are more than capable),, as its a real pig and this will definitely save time,, but thx anyhow..! Steve Link to post Share on other sites
VR6Pete 1,455 Posted May 15, 2015 Report Share Posted May 15, 2015 Steve, There is a detailed guide in the club member knowledge vault section. As you are a club member you have access to this Thanks. Pete Link to post Share on other sites
steveFC 0 Posted May 15, 2015 Author Report Share Posted May 15, 2015 Thanks Pete, saw this,, cannot face it,, way too scary! haha its no biggy,, will give it to a garage,, was just on the off chance someone nearish fancied some extra work.. Link to post Share on other sites
vr6turbo 27 Posted May 18, 2015 Report Share Posted May 18, 2015 done 2 its a right faff VR6CABBS and MJ Vr6 2 Link to post Share on other sites
paceo 22 Posted May 27, 2015 Report Share Posted May 27, 2015 done a few! its a shit job! Link to post Share on other sites
dom.joy 87 Posted May 28, 2015 Report Share Posted May 28, 2015 I wouldnt say it's that bad if you take your time Link to post Share on other sites
rsweeney 40 Posted May 28, 2015 Report Share Posted May 28, 2015 (edited) It's very tedious, not all that bad though! id seriously recommend changing the foam on the panels inside the ducting whilst your at it as I'm having to strip down the dash again for this Edited May 28, 2015 by rsweeney rsweeney 1 Link to post Share on other sites
B4VR6 193 Posted May 28, 2015 Report Share Posted May 28, 2015 It's very tedious, not all that bad though! id seriously recommend changing the foam on the panels inside the ducting whilst your at it as I'm having to strip down the dash again for thisFunny enough I have to do the same to mine. It's just time consuming mostly. All the plugs are different so you can't mix them up. The only issue is not losing any screws and remembering which one is for where. Link to post Share on other sites
paceo 22 Posted May 28, 2015 Report Share Posted May 28, 2015 It's very tedious, not all that bad though! id seriously recommend changing the foam on the panels inside the ducting whilst your at it as I'm having to strip down the dash again for this is that to do with the heating? i only get slightly warm air now! the foam was fecked! Link to post Share on other sites
rsweeney 40 Posted May 29, 2015 Report Share Posted May 29, 2015 (edited) Yeah I only get slightly warm air and it's because all of the foam has come off the heater control doors ! Going to replace it with some HVac tape someone recommend using Edited May 29, 2015 by rsweeney Link to post Share on other sites
rsweeney 40 Posted May 29, 2015 Report Share Posted May 29, 2015 Funny enough I have to do the same to mine. It's just time consuming mostly. All the plugs are different so you can't mix them up. The only issue is not losing any screws and remembering which one is for where.Out of interest what are you using to replace the foam ? Link to post Share on other sites
paceo 22 Posted May 29, 2015 Report Share Posted May 29, 2015 Yeah I only get slightly warm air and it's because all of the foam has come off the heater control doors !Going to replace it with some HVac tape someone recommend using same as mine, got to white the dash out again! is it a heater box out again? i cant remember Link to post Share on other sites
B4VR6 193 Posted May 30, 2015 Report Share Posted May 30, 2015 Out of interest what are you using to replace the foam ?Dynomat Link to post Share on other sites
rsweeney 40 Posted June 4, 2015 Report Share Posted June 4, 2015 (edited) dyno mat would probably do the job nicely come to think of it, better than a bit of tape !I think it's heater box removal unless you can split the box inside the car after removing dash I will let you know as I'm doing it very soon ! Edited June 4, 2015 by rsweeney Link to post Share on other sites
B4VR6 193 Posted June 5, 2015 Report Share Posted June 5, 2015 Heater box needs to come out to seperate it, to get the flaps out. There's two inside Link to post Share on other sites
