ssaunders 199 Posted May 26, 2015 Report Share Posted May 26, 2015 Hi all, I know this is out there if I looked but I'm time limited (fitting Friday). Putting mk4 rear calipers on the VR its a late P plate, will I need to change the pipes? I believe yes but wanted to confirm with the guru's as I wasn't sure if later VR's already had banjos?Thanks in advance.Steve Link to post Share on other sites
Mk3highline 287 Posted May 26, 2015 Report Share Posted May 26, 2015 Yeah you need to change the rear pipes and there available from eBay £35 ishBut the problem I had was that the normal size for the banjo bolt is m10 but the calipers I got off a mk4 had the m12 fitting So get the calipers first to see the size of the banjo bolts Bealieboy 1 Link to post Share on other sites
