Cooz93 66 Posted May 31, 2015 Report Share Posted May 31, 2015 Hi guys. As my cars in bits and access to the underside and inside arches is pretty easy. I was thinking about giving them a coat of underseal. What sort of prep work would I have to do? Will I need to buff it back of is there stuff that can go straight on? Floor is pretty clean and dirt free, arches have a little bit if light grit coating.. Any input appreciated Link to post Share on other sites
HopefulVr6 10 Posted May 31, 2015 Report Share Posted May 31, 2015 I am not an expert but I would say as long as it is in good nick just make sure you de-grease it completely and then it can go straight over. No need to sand if the factory coating is in good enough shape and rust-free. The better advice I can give though is use bilt-hamber products - http://www.bilthamber.com/ - . You could probably use Dynax-UB and then use Dynax-S50, etc, they are miles better than any other stuff and if you don't use their products you will kick yourself when you get told about how much they outperform the other products on the market!! Give them a call they will be happy to help. Link to post Share on other sites
Cooz93 66 Posted May 31, 2015 Author Report Share Posted May 31, 2015 Thanks for the reply! There isn't any rust visible, still to have a poke about. The arches are covered in a light layer of grit/mud. I think they would clean up easy enough. Unfortunately I don't have access to a jet wash at my lock up, or power for that so can't give it a good scrub. Will have a look at that website. Cheers mate:) Link to post Share on other sites
Cooz93 66 Posted June 1, 2015 Author Report Share Posted June 1, 2015 Thought I'd add this in hear before starting a new thread. Looking to remove the fuel tank on the car. How difficult is this? Awkward? Anyone had any advice Link to post Share on other sites
damian8588 11 Posted June 1, 2015 Report Share Posted June 1, 2015 It's pretty simple and easy enough to do you got a bolt up by filler neck and the 5 bolts on the straps hope that helps Link to post Share on other sites
