ky_uk 304 Posted August 20, 2015 Author Report Share Posted August 20, 2015 https://vimeo.com/136839229 Well it started today it sounds rough as hell!! Back to the workshop!!!! Link to post Share on other sites
ky_uk 304 Posted August 20, 2015 Author Report Share Posted August 20, 2015 At least it looks good 35i-VR6 and Dave_ciw 2 Link to post Share on other sites
Dave_ciw 507 Posted August 20, 2015 Report Share Posted August 20, 2015 Trial and error buddy... Is that intake and MAF housing big enough for FI? Will it not confuse the ECU.. Link to post Share on other sites
ky_uk 304 Posted August 20, 2015 Author Report Share Posted August 20, 2015 https://vimeo.com/136841534Try 3 disconnected the MAF and it runs sweet now I have 2 problems I now know some bearings have gone somewhere along the auxiliary and the mouse farting sound is air escaping from silicone Dave_ciw and bennyk 2 Link to post Share on other sites
JayzVr 106 Posted August 20, 2015 Report Share Posted August 20, 2015 This bolt has been sent to destroy me mentally!!!!!!You need a longer bit mate I had the same problem it's a pain to get out. Link to post Share on other sites
ky_uk 304 Posted August 20, 2015 Author Report Share Posted August 20, 2015 You need a longer bit mate I had the same problem it's a pain to get out. I have ordered some but just waiting Link to post Share on other sites
ky_uk 304 Posted August 20, 2015 Author Report Share Posted August 20, 2015 https://vimeo.com/136842386 no more mouse farts lol c00k, 35i-VR6 and bennyk 3 Link to post Share on other sites
JayzVr 106 Posted August 20, 2015 Report Share Posted August 20, 2015 I have ordered some but just waiting I got mine from machine mart, cheap but they do the job lolWhere are you getting your cage from? Link to post Share on other sites
ky_uk 304 Posted August 20, 2015 Author Report Share Posted August 20, 2015 I got mine from machine mart, cheap but they do the job lolWhere are you getting your cage from?Got the cage from here http://www.sportseats4u.co.uk/motorsport-roll-cages/cat_599.html Link to post Share on other sites
JayzVr 106 Posted August 20, 2015 Report Share Posted August 20, 2015 Got the cage from here http://www.sportseats4u.co.uk/motorsport-roll-cages/cat_599.htmlCheers mate, have you gone for a bolt in one Link to post Share on other sites
ky_uk 304 Posted August 20, 2015 Author Report Share Posted August 20, 2015 Yes but its FIA approved and I am gonna weld it. Link to post Share on other sites
ky_uk 304 Posted August 20, 2015 Author Report Share Posted August 20, 2015 Trial and error buddy... Is that intake and MAF housing big enough for FI? Will it not confuse the ECU.. I don't think the standard Maf will work, however I am soon at the end of my knowledge and need it remapping Link to post Share on other sites
ky_uk 304 Posted August 20, 2015 Author Report Share Posted August 20, 2015 Upon further inspection I know the bearings in the supercharger pulley has gone also I think the the other sound is a failed head gasket, the previous owner said he put double head gasket on the block but I am starting to not believe a thing he said.So new pulleys, new spacer plate, new gaskets all round and new bearings on the charger if anyone has anymore input I would really appreciate it not long before the remap. Link to post Share on other sites
ky_uk 304 Posted August 20, 2015 Author Report Share Posted August 20, 2015 This should sort the charger out!!!! D11PS 1 Link to post Share on other sites
ky_uk 304 Posted August 21, 2015 Author Report Share Posted August 21, 2015 Thinking of de cat, I wonder if the waste fuel would send a few flames out of the exhaust Link to post Share on other sites
ky_uk 304 Posted August 21, 2015 Author Report Share Posted August 21, 2015 Best way to put on stand ? Gearbox mount holes or the engine mount holes ? Link to post Share on other sites
Airone 16 Posted August 21, 2015 Report Share Posted August 21, 2015 (edited) Engine mount... For the centre of gravity if nowt else.... Edited August 21, 2015 by Airone Link to post Share on other sites
ky_uk 304 Posted August 21, 2015 Author Report Share Posted August 21, 2015 (edited) gearbox...For the centre of gravity if nowt else.... That is what I am doing I researched it today and it can stress he block mounting from the side, so your right Airone only problem is now I need a clutch removal tool I love all the new things I am learning Edited August 21, 2015 by ky_uk Airone 1 Link to post Share on other sites
ky_uk 304 Posted August 21, 2015 Author Report Share Posted August 21, 2015 De cat kit in the post daveyboy 1 Link to post Share on other sites
c00k 435 Posted August 22, 2015 Report Share Posted August 22, 2015 (edited) I mounted my engine on the stand, from the rear engine mount holes. You don't need the black extension arms.And you need to make a spacer, I used some uni-strut. To level the side of engine. It will give you easier access to the clutch and timing chains. This was mine... Edited August 22, 2015 by c00k Link to post Share on other sites
ky_uk 304 Posted August 22, 2015 Author Report Share Posted August 22, 2015 I mounted my engine on the stand, from the rear engine mount holes. You don't need the black extension arms.And you need to make a spacer, I used some uni-strut. To level the side of engine. It will give you easier access to the clutch and timing chains. This was mine... I saw people doing that but was worried about stressing the engine, I guess that's not the case because yours is fine and more to the point you make a good point about access to chains. Link to post Share on other sites
ky_uk 304 Posted August 22, 2015 Author Report Share Posted August 22, 2015 Finally getting somewhere!!!! Link to post Share on other sites
ky_uk 304 Posted August 22, 2015 Author Report Share Posted August 22, 2015 (edited) Shirt arrived it's quality!!! Edited August 22, 2015 by ky_uk daveyboy 1 Link to post Share on other sites
ky_uk 304 Posted August 22, 2015 Author Report Share Posted August 22, 2015 Wow this engine is dirty!!!!! Dave_ciw 1 Link to post Share on other sites
Dave_ciw 507 Posted August 23, 2015 Report Share Posted August 23, 2015 I was going to do it this way but I have read some disaster stories of these smaller engine stands coping well. Chains have already been done on mine thank god so no need for me to get in their bottom end lol Link to post Share on other sites
