problem is with my 1994 golf vr6, just changed headgasket, rebuilt cylinder head and runs sweet as a nut, however oil temp and coolant temp seem to be slightly high.
on a gentle drive around 35mph oil sits at 98-100, coolant 90 but creeps just shy of 100 sometimes if moving slowler.
Cylinder head has been rebuilt, new shell HX7 10w40 oil and genuine VW filter, hydraulic lifters, NGK Spark plugs, lambda sensor, inlet manifold temp sensor, all gaskets etc.
Runs really smooth, no leaks, but noticed there isn't masses of pressure in the cooling system ( water pump is clearly working as i can see coolant being disturbed in the header tank )
any ideas
Edited by rsweeney
thermostat is a new genuine part, its got full circulation as all the pipes are hot and i've tried bleeding the cooling system a few times but there are still small bubbles of air when you feel the upper matrix hose! trying a spare expansion cap today as i have a feeling that its not keeping system under pressure
Pressure test done no leaks at 1bar, fans kick in and belt is good, when driving the temp stays down around 90, only goes above to around 95 when crawling slowish in traffic but fans pull it back to under 90.
Oil is sitting around 96-98 , it's an auto so may be why it runs hotter but don't know if these temps are normal.
Mine sits at water temp 90 constantly, it's a manual. I've seen oil temps to 100 with the hot weather we've had on a brisk 80mph run.
Vr's are well known to run hot but yours doesn't seem especially so. Fans kick in ok and the cooling system isn't leaking, so that side is functioning ok. Maybe it's just an auto thing, is the gearbox included in the cooling system? Tourque converters can run rather hot I believe.
Is your after run pump working? It should whir into life when you switch on the ignition and continue until a few mins after you switch off.
aux pump is working , but yeah the auto box has an oil cooler on top which means it will be picking up heat from there as well so could be.
next plan is a spare oil cooler i have for the gearbox as well as a new oil cooler for the engine
Replace oil cooler if not done already. I did this and saw a big drop in temps
Thanks mate sounds promising i will give this a go as i havent changed this as yet, does it matter which one you go for as there are two types?
Edited by rsweeney
