ibs 308 Posted August 6, 2015 Report Share Posted August 6, 2015 I'm looking to improve the handling on my car. I have already had it polybushed so I think the next step would be the anti roll bars. Is it worth replacing them for the Eibach or H&R etc? Link to post Share on other sites
c00k 435 Posted August 6, 2015 Report Share Posted August 6, 2015 (edited) Best thing I can recommend for handeling is correctly setup coilovers, and courner weights. Correct length and weight spring for desired ride height, And take it to a specialist garage that can set up the courner weight correctly and tweak the coilovers. As most cheaper coilovers come with generic springs, using same springs for TDi, 1.4, 1.8, 2.0, and 2.8. Where as standard springs would all be differnt weight ratings, for the different weight engines. This is the same way professional Motorsport would set up there suspension. Uprated anti roll bars will help, but courner weights and correctly set up coilovers will be much better. Also an LSD would help a huge amount. Edited August 6, 2015 by c00k ibs 1 Link to post Share on other sites
Bealieboy 1,625 Posted August 6, 2015 Report Share Posted August 6, 2015 (edited) I can recommend the eibachs, I've got them on mine and its stiffened it up a treat. As Cook says, corner weight set up would be fantastic but I reckon you need to be into an expensive set to get the adjustments required for dampening, bound and rebound etc. eibachs or h&r arbs will be cheap and very useable by comparison.Also a 4 wheel alignment and camber adjustment will work wonders. Edited August 6, 2015 by Bealieboy ibs 1 Link to post Share on other sites
dale p 62 Posted August 7, 2015 Report Share Posted August 7, 2015 Eibachs are great but if can source neuspeed they are awesome ibs 1 Link to post Share on other sites
dubspy 19 Posted August 12, 2015 Report Share Posted August 12, 2015 I run Eibachs and think they are awesome well worth while, made a huge change.. ibs 1 Link to post Share on other sites
ibs 308 Posted August 16, 2015 Author Report Share Posted August 16, 2015 Thanks for the replies. I ended up ordering a set of h&r anti roll bars. Hopefully get them on in the next couple of weeks. I have been debating weather to change my coilovers for something better as well. Currently have AP on but I don't really like them. They seem to be too bouncy. Bealieboy 1 Link to post Share on other sites
Bealieboy 1,625 Posted August 16, 2015 Report Share Posted August 16, 2015 Get some damping adjustable ibs, I probably wouldn't be able to run my Stupid rear wheels without! Link to post Share on other sites
ibs 308 Posted August 17, 2015 Author Report Share Posted August 17, 2015 Get some damping adjustable ibs, I probably wouldn't be able to run my Stupid rear wheels without! Cheers Bealieboy. Do you know which makes have adjustable dampening mate? Link to post Share on other sites
Bealieboy 1,625 Posted August 17, 2015 Report Share Posted August 17, 2015 Spax, weitec, gaz, kw. Check awesomegti website. Link to post Share on other sites
