JayzVr 106 Posted August 8, 2015 Report Share Posted August 8, 2015 Can someone tell me what this is and what it does cause it's started buzzing really loud? Link to post Share on other sites
daveyboy 897 Posted August 8, 2015 Report Share Posted August 8, 2015 Is it not the auxiliary water pump Jay? I can't really see that we'll on the picture Link to post Share on other sites
JayzVr 106 Posted August 8, 2015 Author Report Share Posted August 8, 2015 Is it not the auxiliary water pump Jay? I can't really see that we'll on the pictureI'll try get a better pic Link to post Share on other sites
daveyboy 897 Posted August 8, 2015 Report Share Posted August 8, 2015 I'm pretty certain it's the auxiliary water pump. It kicks in when you turn your engine off Link to post Share on other sites
JayzVr 106 Posted August 8, 2015 Author Report Share Posted August 8, 2015 Link to post Share on other sites
daveyboy 897 Posted August 8, 2015 Report Share Posted August 8, 2015 Yeah it's the auxiliary water pump Jay ky_uk 1 Link to post Share on other sites
JayzVr 106 Posted August 8, 2015 Author Report Share Posted August 8, 2015 Yeah it's the auxiliary water pump Jay Ok cool shouldn't be buzzing then lol Link to post Share on other sites
daveyboy 897 Posted August 8, 2015 Report Share Posted August 8, 2015 Not loud. Take the one off your other engine and try it Link to post Share on other sites
ssaunders 199 Posted August 8, 2015 Report Share Posted August 8, 2015 Hi, definitely 2ndary pump, how do you mean by buzzing? engine on or off? you normally hear it when you turn off the engine i read somewhere it can run on for upto 10 mins after a run. i have known a few who bypass it when it goes wrong as they are about £100, i wouldnt personally and didnt when mine went tits up! how hot does your engine get (coolant wise)? if your fiddling be careful of the lower hose connection as its plastic and can get brittle.good lucks Link to post Share on other sites
JayzVr 106 Posted August 8, 2015 Author Report Share Posted August 8, 2015 Hi, definitely 2ndary pump, how do you mean by buzzing? engine on or off? you normally hear it when you turn off the engine i read somewhere it can run on for upto 10 mins after a run. i have known a few who bypass it when it goes wrong as they are about £100, i wouldnt personally and didnt when mine went tits up! how hot does your engine get (coolant wise)? if your fiddling be careful of the lower hose connection as its plastic and can get brittle.good lucksIt's starts buzzing really loud when ignition is on not running, is there a link anywhere on how to bypass it? Link to post Share on other sites
ssaunders 199 Posted August 8, 2015 Report Share Posted August 8, 2015 Hi, literally take it out and join the hoses that went in. I would replace though as VR's do run hot.S Link to post Share on other sites
Bealieboy 1,625 Posted August 8, 2015 Report Share Posted August 8, 2015 Yep, worth keeping the secondary water pump on jay, anything that helps keep the car a bit cooler helps! Link to post Share on other sites
JayzVr 106 Posted August 9, 2015 Author Report Share Posted August 9, 2015 Yep, worth keeping the secondary water pump on jay, anything that helps keep the car a bit cooler helps!Hi, literally take it out and join the hoses that went in. I would replace though as VR's do run hot.SOk cheers guys Link to post Share on other sites
VR6CABBS 1,311 Posted August 12, 2015 Report Share Posted August 12, 2015 It's starts buzzing really loud when ignition is on not running, is there a link anywhere on how to bypass it?Omg. This is the issue I've been having. Only does it now and again. It done it again a few days ago when I was sat at traffic lights. I've also noticed a water circulating noise aswell when I switch the ignition to red lights. Only happened since I fitted my samco's . Doesn't seem to have any air in the system. Runs up to temp and fans kick in as normal. Link to post Share on other sites
JayzVr 106 Posted August 12, 2015 Author Report Share Posted August 12, 2015 Omg. This is the issue I've been having. Only does it now and again. It done it again a few days ago when I was sat at traffic lights. I've also noticed a water circulating noise aswell when I switch the ignition to red lights. Only happened since I fitted my samco's . Doesn't seem to have any air in the system. Runs up to temp and fans kick in as normal.That's what mine does when I switch ignition on I can hear water running through some where then it starts buzzing, starting to get on my tits now! VR6CABBS 1 Link to post Share on other sites
VR6CABBS 1,311 Posted August 12, 2015 Report Share Posted August 12, 2015 That's what mine does when I switch ignition on I can hear water running through some where then it starts buzzing, starting to get on my tits now!People keep saying its air in the system. I'm not convinced. Have you changed any hoses? Link to post Share on other sites
JayzVr 106 Posted August 12, 2015 Author Report Share Posted August 12, 2015 People keep saying its air in the system. I'm not convinced. Have you changed any hoses?Yeah I put some red hoses on? Link to post Share on other sites
dom.joy 87 Posted August 12, 2015 Report Share Posted August 12, 2015 Mine does the same since fitting samcos. Tried burping air several times so now I just leave it.Buzzing I'd put down to the electric pump working but being a little tired. Just leaving mine until it dies completely. Link to post Share on other sites
JayzVr 106 Posted August 12, 2015 Author Report Share Posted August 12, 2015 Mine does the same since fitting samcos. Tried burping air several times so now I just leave it.Buzzing I'd put down to the electric pump working but being a little tired. Just leaving mine until it dies completely.Everything works as it should I've not had a overheating issue as of yet, I have a spare pump off my black vr so I'll fit that once it goes Link to post Share on other sites
cactusjackslade 146 Posted August 12, 2015 Report Share Posted August 12, 2015 There is a lot of different opinions as to when this pump should be running and if it's needed at all. After much reading and revision I managed to get to the bottom of it. The vr cylinder head also acts as an exhaust manifold for the front three cylinders and so tents to run hot. The secondary pumps job is to assist the circulation off coolant around the head during running and for a short period after engine switch off to stop any localised overheating. the purpose of the after run feature is to keep the coolant circulating around the head while the hot engine cools. Without this the coolant would be sitting in a red hot head without circulation causing localised overheating in your head. So it is a good thing to have working correctly. The after run pump should run with ignition on and then for roughly 10 minutes after you switch ignition off IRRELEVENT of temperature or even if the engine has been started. It's a set sequence. I found My pump the same as many other vrs out there today only ran with ignition on and stopped as soon as I switch the ignition off. I have to say I never noticed a problem and it stopped like this for a few years. However when I added a turbo to the engine things were different. A few times after a long run out I pulled on the drive with engine temperatures reading normal. Roughly 3 minutes after switching engine off the water boiled and bubbled in the expansion tank. I could only put this down to the extra heat stored inside the turbo and manifold boiling the coolant inside the head once the main pump driven by the engine stopped. After a few test I found a faulty fan control module to be the cause of my secondary pump not running for 10 mins after shut off. Once that was replaced its been fine. MJ Vr6 and Bealieboy 2 Link to post Share on other sites
dom.joy 87 Posted August 13, 2015 Report Share Posted August 13, 2015 I thought about ditching mine but read something similar to the above and kept it.The car is so loud anyway that it has never bothered me Link to post Share on other sites
green joker 7 Posted August 22, 2015 Report Share Posted August 22, 2015 Hey guys I have a problem with my auxiliary water pump, it used to turn on when the ignition was turned on but recently it isn't doing that and after driving the car ( temperatures in normal range ) it still didn't come on? Any advice on what could be going on? This is my first vr Link to post Share on other sites
rsweeney 40 Posted August 25, 2015 Report Share Posted August 25, 2015 (edited) The water gushing sound is because with OEM hoses there is a little one way valve in the coolant hose going into the throttle body , the Samco hose doesn't come with this so remove it from OEM hose and push it into the Samco, this sorted the trapped air noise your referring to ! Edited August 25, 2015 by rsweeney Link to post Share on other sites
