londonflu 2 Posted August 21, 2015 Report Share Posted August 21, 2015 Up another night after OBD2 to OBD1 engine swap engine swap. Car is a 1996 Jetta GLX VR. We converted everything over from OBD2 engine, including intake manifold, throttle body, wiring harness, exhaust manifold and ECU, which was DOA after install. Installed good used ECU and pulled these codes. So far I've checked and cleaned all grounds, fuses, shes getting power to brand new coil pack, plugs & wires. She's almost starts, then nothing. New ECU is 021906259A according to scanner, original was 021906259N, so that tells me right there that car had many issues before I rescued her. Anyway here's the codes, any help would be very much appreciated, I've been up many of nights after work. Chassis Type: 1H - VW Golf/Vento III (1992 > 1999)Scan: 01 02 03 08 12 15 25 41 56-------------------------------------------------------------------------------Address 01: Engine Labels: 021-906-259-AES.lblPart No: 021 906 259 Component: C2 Inc 2008.005R HS V03 Coding: 00000Shop #: WSC 00066 VCID: D2A028A11E29298EF27-4AE64 Faults Found:17952 - Angle Sensor 1 for Throttle Actuator (G187) P1544 - 35-00 - Signal too Large16505 - Throttle Position Sensor (G69) P0121 - 35-00 - Implausible Signal16502 - Engine Coolant Temp. Sensor (G62) P0118 - 35-00 - Signal too High16725 - Camshaft Position Sensor (G40) P0341 - 35-00 - Implausible SignalReadiness: 0000 0000 Link to post Share on other sites
