Has anyone installed this OEM fan switch to their vr6, part number : 1H0959481D
instead of the standard : 1H0959481B
Only differences are switching temnperatures , it seems to only be available in the states but going to try and order through VW.
If not where can i get a low temp fan switch in the UK ?
cheers
Edited by rsweeney
I'm after a fan switch, looking at it the standard thermostat opens at 80 degrees and the standard fan switch puts 1st speed on at 95 degrees.
I think its better to change the fan switch and keep the standard thermostat as it will still let the engine heat up quickly but  keep things below 90 using the fans
Edited by rsweeney
