rsweeney 40 Posted August 30, 2015 Report Share Posted August 30, 2015 (edited) Has anyone installed this OEM fan switch to their vr6, part number : 1H0959481D instead of the standard : 1H0959481B Only differences are switching temnperatures , it seems to only be available in the states but going to try and order through VW. If not where can i get a low temp fan switch in the UK ? cheers Edited August 30, 2015 by rsweeney Link to post Share on other sites
daveyboy 897 Posted August 30, 2015 Report Share Posted August 30, 2015 Are you after a thermostat that get the fans to cut in earlier? You can get a 71° thermostat from dub power I think Link to post Share on other sites
rsweeney 40 Posted August 30, 2015 Author Report Share Posted August 30, 2015 (edited) I'm after a fan switch, looking at it the standard thermostat opens at 80 degrees and the standard fan switch puts 1st speed on at 95 degrees. I think its better to change the fan switch and keep the standard thermostat as it will still let the engine heat up quickly but keep things below 90 using the fans Edited August 30, 2015 by rsweeney Bealieboy 1 Link to post Share on other sites
VR6Pete 1,455 Posted August 30, 2015 Report Share Posted August 30, 2015 Back in the day, Awesome GTI sold the lower temp fan switch and thermostat. Link to post Share on other sites
J4Y VR 36 Posted August 30, 2015 Report Share Posted August 30, 2015 You will have Buy the fan switch plug from awesome for another £20. Link to post Share on other sites
rsweeney 40 Posted August 30, 2015 Author Report Share Posted August 30, 2015 just seen that so new plug and sensor , would be ideal if i could get the OEM sensor as it would be a straight fit - http://www.ecstuning.com/ES1369/Notify/ Link to post Share on other sites
