1994 Passat VR6 ignition leads
I'm located in the USA but here is an example.. these are for mk4 VR6 but are identical to your Passat VR6, only difference is that these have a loop for your finger to pull the boot off the plug whereas the original wires for your 94 require a tool to remove boot from plug.
http://www.amazon.com/Bosch-09488-Premium-Spark-Plug/dp/B000BYENNA
