Cooz93 66 Posted September 21, 2015 Report Share Posted September 21, 2015 Hi guys. Need to replace something on the distributor as it snapped. The thing with the 3 pins, the plug on the harness but what will I need to replace the broken part. Can be seen in this pic.. Link to post Share on other sites
lilfuzzer 48 Posted September 21, 2015 Report Share Posted September 21, 2015 now I see it I have a dizzy that the part is broken from the main unit but the connector ok. not sure if you could make a good one out of the two? Link to post Share on other sites
Cooz93 66 Posted September 21, 2015 Author Report Share Posted September 21, 2015 now I see itI have a dizzy that the part is broken from the main unit but the connector ok. not sure if you could make a good one out of the two?How much would you be after? Suppose it's worth a try! Link to post Share on other sites
boab3 164 Posted September 23, 2015 Report Share Posted September 23, 2015 Check out this item I found on eBay: http://pages.ebay.com/link/?nav=item.view&id=191698227234&globalID=EBAY-GB&alt=web Cooz93 1 Link to post Share on other sites
