want anything? - 100's of golf vr6 / gti parts in here - south london
LOCATED SOUTH LONDON IN NORTH KENT - 07773114069 is my number. Mk3 gti 8v front end with fan £5, rear gti / vr6 rear axle, offside caliper is slightly binding complete £30 or can split, gti / vr6 front subframe with wishbones, anti roll bar and steering rack £35, leak free power steering pipes £20, UJ joint £5, rear engine mount £5, 8v gti gear linkage £5, rear vr6 / gti suspension shocks £10 the pair, sachs quality clutch / flywheel receipt dated 2013 £10, gti 8v dizzy, hall sender works fine so revvs above 5k £15, gti 8v new ht leads and dizzy cap £10, never used 5 stud spare wheel with brand new tyre £10, gti / vr6 brake servo and master cylinder £10, gti 8v brake servo pipe £5, mk3 heater controls £5, vr6 / gti front subframe leak free power steering pipe with hoses £5, gti / vr6 battery negative cable £5, gti / vr6 alternator cable to starter motor £5, mk3 boot struts new-ish £5, gti 8v front breather pipe no splits £10, gti 8v front engine mount bracket £5, mk3 adjustable steering column £5, gti 8v new-ish lambda sensor, receipt dated 2013 £10, gti 8v clutch cable £5, mk3 seat brackets to put mk3 seats into a mk2 £25, spare rear seat bracket £5, gti / vr6 very early 280mm front calipers, perfect working order, same as g60 i believe £30, gti / vr6 fan control unit £5, gti 8v starter motor receipt dated 2011 £15, mk3 front wiper motor £5, gti 8v pedal box £5, glovebox with fully working latch £8, heater surrounds with chrome outers £5, mk3 header tank £2, mk3 sunroof motor £5, mk3 steering rack UJ rubber boot cover thats not split which is rare £10, gti 8v ecu with immobilizer black box and key £15, mk3 heater motor fan £5, mk3 interior loom with electric window loom and a £325 sigma alarm, comes with alarm fob and receipt of £325 only £15, vr6 / gti electirc window and electric mirror door looms £10 the pair, mk3 chrome door pins £5 the pair, front mk3 gti / vr6 subframe £5, front gti / vr6 engine mount £5, nice rust free mk3 door for a 3-door in non metallic black, not really any dents £5, 3x gti / vr6 sill bodykit covers, ok condition £5 for the 3x, chrome bonnet opening struts, some rust in places £5, white gti 8v clocks slight hairline crack in white bit but you dont really notice it £5, early rare gti / vr6 non airbag 3 spoke steering wheel £20, gti 8v power steering pump pulley £5, chrome sill strips with gti logo on them £5, clear wing indicators, slips have snapped so stick them on £2, gti 8v airbox and fully working maf sensor £15. LOCATED SOUTH LONDON IN NORTH KENT, 07773114069 is my number  :rolleyes:
  • 1 month later...
