Batler182 1 Posted December 10, 2015 Report Share Posted December 10, 2015 Hi guys,I've got a fault code come up on my Vr6 saying g62 coolant temp sensor open or short to plus. Any ideas what would cause this or is it obviously a broken wire somewhere?Cheers Link to post Share on other sites
Batler182 1 Posted December 10, 2015 Author Report Share Posted December 10, 2015 I've only got two coolant sensors, should I have three? Link to post Share on other sites
c00k 435 Posted December 15, 2015 Report Share Posted December 15, 2015 You only have 3 if you have air con. Link to post Share on other sites
VR6Pete 1,455 Posted December 16, 2015 Report Share Posted December 16, 2015 You only have 3 if you have air con.Not always the case. My Corrado has 3 sensors, but no air-con. My 3rd sensor (black 2 pin) is stage 3 fans. Link to post Share on other sites
michael5556 247 Posted December 17, 2015 Report Share Posted December 17, 2015 Thats only on rado's i think. should be a yellow and blue. blue is the important one as yellow is just for clocks.probably a broken wire or something Link to post Share on other sites
rsweeney 40 Posted December 20, 2015 Report Share Posted December 20, 2015 i need help with this aswell mine has just thrown up Fault code 00522 coolant temp sensor G62. Not sure if this is referring to the blue ECU sensor, yellow aux water pump & dash gauge sensor or the brown aircon sensor ( i still have the wiring connected to this sensor even though i have removed the aircon and it has never given me this code before ) Car runs well so wouldnt think it was the blue ECU coolant temp sensor Link to post Share on other sites
rsweeney 40 Posted December 21, 2015 Report Share Posted December 21, 2015 turned out to be poor earth - main earth strap from battery terminal to bell housing Link to post Share on other sites
