Phylo99 0 Posted January 11, 2016 Report Share Posted January 11, 2016 Hi Im Philip I have a P reg VR6 Highline all original in Black owned for 2 years - Its been off the road for a year waiting for me to get around to a huge list of work it failed an MOT on to get back on the road First job I wanted to tackle is the combined no ABS / Airbag light working on ignition key turn or start up .. I took the dashboard light out and it was not connected at the rear and thought great ! plug it in it will work .. No not the case .. I tested the two bulbs they have a circuit so they are not broken .. the brakes all work fine having new pads, discs all round and the ABS works when you brake hard on a slippy surface.. does anyone have any advice on where I should look next to resolve this ? Much appreciated Philip Link to post Share on other sites
richierich37 236 Posted January 22, 2016 Report Share Posted January 22, 2016 Hi philip Link to post Share on other sites
VR6CABBS 1,311 Posted January 24, 2016 Report Share Posted January 24, 2016 Welcome to the club Philip. The first thing i would be doing is getting it plugged into vagcom and see what fault codes it throws up. ABS fault could mean a number of things. ABS sensors faultyABS rings corrodedABS pump FaultyABS module Faulty etc etc. Get it plugged in to see what codes come up..... Link to post Share on other sites
Phylo99 0 Posted February 1, 2016 Author Report Share Posted February 1, 2016 Hi thanks for the message will any garage computer diagnostics show the fault codes or does it have to be a Vagcom tester? Best regards Phil Link to post Share on other sites
VR6CABBS 1,311 Posted February 2, 2016 Report Share Posted February 2, 2016 Hi thanks for the message will any garage computer diagnostics show the fault codes or does it have to be a Vagcom tester? Best regards PhilIts always going to be best with Vagcom. You can actually buy cheap copy vagcom leads off ebay but if you use one dont let it connect to the internet or they will brick your cable. Link to post Share on other sites
VR6Pete 1,455 Posted February 7, 2016 Report Share Posted February 7, 2016 welcome to the forum pal get your build thread up and running mate Link to post Share on other sites
