olivermorganclarke 6 Posted January 24, 2016 Report Share Posted January 24, 2016 I have a VR6 92 that i brought a couple months ago slowly been fixing it up before i put it on the road. In the engine bay i found this connector not sure what it is suppose to be connected to any info would be very helpful. its a female connector two pin wires are red and brown, it is located at back right of the engine bay. Bealieboy 1 Link to post Share on other sites
Bealieboy 1,625 Posted January 24, 2016 Report Share Posted January 24, 2016 Possibly for the secondary water pump that looks like it might be missing?! VR6Pete and olivermorganclarke 2 Link to post Share on other sites
VR6Pete 1,455 Posted January 24, 2016 Report Share Posted January 24, 2016 Yes, it does look like aux water pump plug. Probably has leaked in the past and removed / disconnected. You should see a pump around the area where the big engine plug is. You'll have remove engine plastics to plug it back if it's simply been disconnected. olivermorganclarke 1 Link to post Share on other sites
olivermorganclarke 6 Posted January 24, 2016 Author Report Share Posted January 24, 2016 (edited) Thanks yes there is evidence of a water leak in the past. I will have a look and see if it has been removed. cheers guys does anyone have a part number? Edited January 24, 2016 by olivermorganclarke Link to post Share on other sites
Vag-hag 147 Posted January 25, 2016 Report Share Posted January 25, 2016 Bosch-VR6-Auxillary-Water-Pump_-0-392-020-024. VW-251-965-561-BRoughly £50 on eBay.de buddy. It's easy to find in engine bay, has two coolant hoses attached to it. They are prone to leaking/ failing over time. olivermorganclarke and VR6Pete 2 Link to post Share on other sites
Vag-hag 147 Posted January 25, 2016 Report Share Posted January 25, 2016 That fits the Corrado anyway, I assume they are the same as golfs? Link to post Share on other sites
