HELP vr6 idle fluctuates when inidicators or heated seat is on?
can anyone help me out as im desperate
my car recently was converted from a GTI 8V to a VR6
the car runs fine but when i have the indicators on the car hunts and if i put the heated seat on the revs go up
i cant see any plugs off in the fuse box and added extra earths under the engine bay but no difference
any help would be much appreciated
What alternator did you use? Sounds like voltage drop or alternator not producing enough juice. You can easily check. Simply attach volt meter to battery when running. Should be producing around 13.9volts. Check see if there is a drop when you put indicators / heated seats on and report back.
