Hi guys. Away to set the gap on my abs sensor to abs ring on my 256mm rear brake set up. Could anyone tell me how close the sensor has to be to the ring to make it affective? Also is there a certain part of the sensor that should be facing the ring. Bigger or small flat? It's been many months since I stripped the original so totally forgot. Much appreciated :)
