olivermorganclarke 6 Posted February 21, 2016 Report Share Posted February 21, 2016 Hello I have been very slowly fixing a a 92 VR6. The Aux water pump was missing and the heater matrix had been by passed. I connected everything to how it should be, the windows steamed up water started coming out of the vents. Now i need to replace the matrix to get it working properly. Does anyone have any advice u am fairly sure its a dash out job is there anything I should do to make sure I do so I do not anything also before I did this foam was comming out of the vents does anyone know where i can get replacement foam? Link to post Share on other sites
Vag-hag 147 Posted February 21, 2016 Report Share Posted February 21, 2016 I just did this on my Corrado. I'm told it can be done without removing the dash but I took the dash out to inspect everything. the foam on the directional flaps in your heater box will be more like dust now. I removed the lot and covered each flap with self adhesive felt from British felt website. Great service from British felt. valeo matrix were oem if you can find one. VR6Pete 1 Link to post Share on other sites
olivermorganclarke 6 Posted February 21, 2016 Author Report Share Posted February 21, 2016 (edited) Thanks man for the advice on the foam! I will look into them. i was just going to buy the heater matrix off of euro parts. only £15-£25 what type of foam did you put back on the flaps? thanks Edited February 21, 2016 by olivermorganclarke VR6Pete 1 Link to post Share on other sites
VR6Pete 1,455 Posted February 21, 2016 Report Share Posted February 21, 2016 100% take your dash out - if you've had water blowing out of your vents there will be pools of coolant in the heater box etc... and you will constantly be steaming up. Top tip - masking tape and write on what each plug is for, taking lots of photos as you go along. It's probably at least a full day job, but you can DIY without the need for a garage to do the work for you.... id also recommend that you get some heaters in the car to dry it all out. If you have a corrado, take great care removing the heater controls as they are very delicate. Pete Link to post Share on other sites
olivermorganclarke 6 Posted February 21, 2016 Author Report Share Posted February 21, 2016 Thanks for the tip dude! Its a golf but i will still be careful with the controls. Defiantly will be a DIY job as i have the time and space thanks man VR6Pete 1 Link to post Share on other sites
Vag-hag 147 Posted February 22, 2016 Report Share Posted February 22, 2016 9 hours ago, olivermorganclarke said: Thanks man for the advice on the foam! I will look into them. i was just going to buy the heater matrix off of euro parts. only £15-£25 what type of foam did you put back on the flaps? thanks http://www.britishfelt.com/admiral-felt-adhesive-1mm.html?search=1mm%20black i used this. It helps to reduce squeaks too. Link to post Share on other sites
VR6Pete 1,455 Posted February 22, 2016 Report Share Posted February 22, 2016 8 hours ago, olivermorganclarke said: Thanks for the tip dude! Its a golf but i will still be careful with the controls. Defiantly will be a DIY job as i have the time and space thanks man No worries. There is a good guide available to club members on doing the heater matrix and is a god send to anyone doing a DIY job. Link to post Share on other sites
olivermorganclarke 6 Posted February 22, 2016 Author Report Share Posted February 22, 2016 Thanks man i will be starting to take it all out tonight. I will have a look at that guide will be signing up for the meber ship soon as! VR6Pete 1 Link to post Share on other sites
dom.joy 87 Posted February 22, 2016 Report Share Posted February 22, 2016 Can only echo the above. Take your time and its really not that bad Link to post Share on other sites
