RBPE 198 Posted April 24, 2016 Report Share Posted April 24, 2016 (edited) Basic guide to explain why your car is going "bat s^&t crazy"! Your ecu, regardless of car, uses a lot of sensory inputs to make it work, how it does this is a part of a recalibration/remapping thread I am doing and too complex for here. Suffice to say, if these sensory inputs are not correct or make no sense to the ecu, it doesn't like it and throws a wobbly! Due to the fact that many sensors can be used for the ecu to check in one area - i.e. it looks at 2 maps with engine rpm v's coolant temp on one and engine rpm v's voltage on the other, it is essentially looking at 3 sensors here. The crank sensor tells it the rpm, the engine coolant sensor the temp and the voltage used for things like sensor readings as well as ignition/injection latency etc... Point being, as a number of sensors are used/intermixed within the ecu to work something out; then; a) what is happening may not be truly indicative of what is causing the fault, and one sensory input fault can cause a number of fault codes so try and find the right one first to save £'s! Almost all the time it is either a problem with a sensor or something is causing a sensor to read some weird readings it doesn't like! The math doesn't add up if you will! So these are a list of common sensors of the Motronic - quick post up off top of my head and model/ecu variances etc; point out any I've missed; MAF/HFM Sensor 02/Lambda sensors Coolant temp sensor Crank and cam position sensors Spark plug damage/coils/coil packs Throttle position sensor/pedal box sensors - ME7 Intake air temp sensor - IAT Manifold absolute pressure sensor - MAP Idle stabilization valve - ISV So - once you understand why it's going mental it's time to find the cause! Two things I would start with; Leaks of some kind can cause air or air related problems and the ecu's trying to work out air/fuel calcs so air that shouldn't be there it'll have a strop! It's free to check this, either visually by looking at it or perhaps the old hose in water trick looking for bubbles? First thing I would recommend really as it's free n easy like yours truly! Secondly, the OBD - On Board Diagnostics that auto electricians plug their laptops into, enabled garages to check problems quickly - VAG-COM/VCDS is what you want to look for. What this does is basically tell you what's having problems and as said, it can and usually is one bit/sensor that starts a chain reaction causing multiple problems cropping up on the scan! There are hundreds of maps all interconnected in some way so it's about trying to use logic - if you've recently played with one area then it could likely be causing a problem in another area if you're getting multiple codes. So check leaks and spend the £20 or so to get a read of the codes if necessary, to save you a lot of time and effort first of all! That's a basic overview of what essentially is happening then, find the cause of the sensor play up, not necessarily the sensor itself! Quick list of common probs; Coils/coil packs - personally seen some bad pro maps destroying coils if you've had it happen - lot's of reasons for problems here - fundamentally important for good spark and everything thereafter! So anything from a bent spark plug due to dropping through to a damaged coil or sensor in the dizzy! MAF - intake systems collapsing, sensor not working, bad reads due to bends/turbulent flow - less of a problem on mk4+ due to glass/ceramic substrate evolution of the ME7 HFM's.over wire early ones. Temp sensor - start/after-start & hot start areas of injection on mk4's for example , car can play up depending on ecu adaptive aspects - "learning" and temp depending, so if playing up then gets better or vice versa - perhaps here or below? 02/Lambda - common problems here too - coking over giving bad readings due to age, brittle at times, can be a prob on later ME7 torque systems due to above temp dep'd aspects and adaptve learning of the ecu - mono lambda problems for fi more technical but similar in terms of adaption routines. Hope that gives you a basic idea of what is going then which covers most problems basics! Little Bosch diagram on the ME7 system to see the various sensors and, unfortunately, why a bit of trial and error may be needed as they are all connected! EDIT: I did this quick note info based on the Bosch system strategy floating about on the web, gives an overview of catalytic monitoring in the ecu and so on so kind of tells you what your computer is doing in monitoring and why it throws codes; https://app.box.com/s/7fvt652zoqapzmfq7fv0rfufs96yv25q 12v info: http://www.volkspage.net/technik/ssp/ssp/SSP_127.PDF VR6 repair manual; http://www.vaglinks.com/Docs/VW/Corrado/VW_Corrado_SLC_AAA_Repair_Manual.pdf V5/FSI: http://www.volkspage.net/technik/ssp/ssp/SSP_195.pdf http://sandbox.enjoybeing.net/veedub/vw_vr6_self_study.pdf Edited August 6, 2018 by RBPE VR6Pete, c00k and rich 3 Link to post Share on other sites
RBPE 198 Posted May 1, 2016 Author Report Share Posted May 1, 2016 (edited) Mods not stickying this? You add this thread to this one here; http://www.vr6oc.com/forum/forums/topic/48201-the-definitive-remapping-thread/ then you have your entire ecu's, the sensors and what causes problems! Just a thought! Edited November 21, 2016 by RBPE Link to post Share on other sites
VR6Pete 1,455 Posted May 1, 2016 Report Share Posted May 1, 2016 Thought I had pinned this already sorry dude RBPE 1 Link to post Share on other sites
RBPE 198 Posted May 1, 2016 Author Report Share Posted May 1, 2016 1 minute ago, VR6Pete said: Thought I had pinned this already sorry dude No worries Pete, nice overview of systems, case of backtracking then. Link to post Share on other sites
mazhar 0 Posted April 10, 2017 Report Share Posted April 10, 2017 Hi my car i don't know what's wrong with it while am driving it's changing gears down wards and switching it'self off can I get help it's golf 5 R32 Link to post Share on other sites
RBPE 198 Posted April 20, 2017 Author Report Share Posted April 20, 2017 (edited) On 4/10/2017 at 7:42 PM, mazhar said: Hi my car i don't know what's wrong with it while am driving it's changing gears down wards and switching it'self off can I get help it's golf 5 R32 When you say switching itself off do you mean closes the throttle? That usually means running lean and is what the ecu does, can be various reasons though, MAF (HFM), dodgy injectors, fuel pump problem etc, also DSG/Mechatronic prob. If it's turning the electrics off then it's usually a short/wiring problem, could be wires or perhaps a loose battery shorting? VCDS/VAG COM is your friend though! Many use copied ones on their own cars due to cost; later ecu's with better OBD programming work better than old ones, RL tends to be better ones, can be windows specific etc, have a look into it dep on your ecu code, should be info on ecu tuning forums; https://www.ebay.co.uk/itm/FOR-VW-AUDI-SKODA-FTDI-FT232RL-VAG-COM-KKL-409-1-OBD2-K-Line-KWP2000-ISO9141-USB/182331196413?hash=item2a73c943fd:g:eu0AAOSwYVlaKg7~ Also ME7 Logger is free but can be temperamental on some ecu's, esp the 6 cylinder ecu's; http://nefariousmotorsports.com/forum/index.php/topic,1079.0title,.html Edited February 14, 2018 by RBPE Link to post Share on other sites
Nick1974 4 Posted August 11, 2017 Report Share Posted August 11, 2017 Hi prob with vr6 mk3 it's like a little miss of engine on low revs between 1000 and 2000 just about 15 16 revs it's sometimes cuts out iv Changed coil pack sparkplugs petrol pump maf crank sensor and still it missing every now and then I'm lost now of what gti do next prob cam sensor is all that's left and iv done fuel filter any advice please I know it's a common fault but tried everything I know that can cause a miss at low revs only a second it missus for then picks up again. Help please it's doin my head in now. Link to post Share on other sites
Nick1974 4 Posted August 30, 2017 Report Share Posted August 30, 2017 ???? Link to post Share on other sites
RBPE 198 Posted September 3, 2017 Author Report Share Posted September 3, 2017 (edited) Have you checked the wiring itself? Any part additions or remap on it? Edited September 3, 2017 by RBPE Link to post Share on other sites
Impalor 1 Posted October 11, 2017 Report Share Posted October 11, 2017 Hi guys im new to this page..i have a jetta 95 vr6 2.8...at a low rpm the car jerks and back fires alot but as soon as i pick up speed the beast comes alive aswell as the handbreak light recently just stays on..any help please.. Link to post Share on other sites
MJ Vr6 79 Posted October 13, 2017 Report Share Posted October 13, 2017 On 11/10/2017 at 8:54 AM, Impalor said: Hi guys im new to this page..i have a jetta 95 vr6 2.8...at a low rpm the car jerks and back fires alot but as soon as i pick up speed the beast comes alive aswell as the handbreak light recently just stays on..any help please.. Have a look at the Coolant Temp Sensor. Had the same prob on my old 96 VR. Stick it on Vagcom and see if there are any error codes. Mj Impalor 1 Link to post Share on other sites
Impalor 1 Posted October 15, 2017 Report Share Posted October 15, 2017 So i just unplugged my MAF..and let it idle without it and plugged it back in after a while problem gone..weird..but thanx Link to post Share on other sites
Impalor 1 Posted October 15, 2017 Report Share Posted October 15, 2017 But now im sitting with another problem..since i changed my battery terminals my cluster stop working aswell as my power windows...not even a click on the motor when i press the button...i mean everything on my cluster stopped working..fuel gauge..rev..speedo not even the clock showing...any ideas to what this can be? Link to post Share on other sites
MJ Vr6 79 Posted October 18, 2017 Report Share Posted October 18, 2017 Reset it. Take the terminals off, hold + & - together for 30sec, re-connect and see. Mj Link to post Share on other sites
Impalor 1 Posted October 18, 2017 Report Share Posted October 18, 2017 Reset it. Take the terminals off, hold + & - together for 30sec, re-connect and see. MjAh thanx buddy ill see what it does MJ Vr6 1 Link to post Share on other sites
Matty81 0 Posted January 6, 2018 Report Share Posted January 6, 2018 Hi all I've got a vento 2.9 vr6 .. haven't really noticed a coolant leak but when i put heater on blows steam threw vents and stinks ... heater matrix perhaps ?? Link to post Share on other sites
MJ Vr6 79 Posted January 8, 2018 Report Share Posted January 8, 2018 On 06/01/2018 at 3:19 PM, Matty81 said: Hi all I've got a vento 2.9 vr6 .. haven't really noticed a coolant leak but when i put heater on blows steam threw vents and stinks ... heater matrix perhaps ?? Most likely. Link to post Share on other sites
