The Monk 50 Posted May 22, 2016 Report Share Posted May 22, 2016 (edited) Hi all.Just been down to the rolling road. Car was and has been fine and never missed a beat since I've owned her.On the way back, the car went lumpy and rough, felt like it was firing on 4 cylinders. Engine light flashed away.Got her back now and stuck a scan tool on her. P0300 - Multiple misfires detected P0303 - Misfire cylinder 3P0305 - Misfire cylinder 5P0306 - Misfire cylinder 6Now I could understand one coil pack going but not two or three in one fell swoop. This screams to me either bad luck OR fuel issue?.No codes appeared regarding cps or MAF or anything else. Just the 4 above.Any ideas chaps?Cheers. Edited May 22, 2016 by The Monk Link to post Share on other sites
The Monk 50 Posted May 22, 2016 Author Report Share Posted May 22, 2016 So I swapped the coil packs around. Faulty cylinders worked and those that were working, misfired and threw codes. I don't normally exceed 5k revs. Coil packs look dead and like the ones that the car rolled out the factory with. Exceeded 5k revs multiple times on the way back. Stressed old components. rich 1 Link to post Share on other sites
rich 40 Posted May 23, 2016 Report Share Posted May 23, 2016 looks like..it does happen..gets hot on rolling rd as well..that eats electrical items,especially old ones...unlucky chap Link to post Share on other sites
The Monk 50 Posted May 23, 2016 Author Report Share Posted May 23, 2016 What you say is true, Rich. I forgot to mention that I did this on the way back, in 1st and 2nd gear after not running on that rolling road, merely a spectator. A spectator because I wanted to avoid issue. So I was a good boy and ended up punished anyway lol. test1 and rich 2 Link to post Share on other sites
test1 1 Posted May 23, 2016 Report Share Posted May 23, 2016 What you say is true, Rich. I forgot to mention that I did this on the way back, in 1st and 2nd gear after not running on that rolling road, merely a spectator. A spectator because I wanted to avoid issue. So I was a good boy and ended up punished anyway lol. Bet you feel cheated now mate and wished you run it on the rollers Sounds like either coil / leads arching out. Usually happens under load I.e first / second. Can't figure out what happened when you swapped coil packs as I'm too tired lol Link to post Share on other sites
rich 40 Posted May 23, 2016 Report Share Posted May 23, 2016 ah righty ho,,,so just seems as you gave it a bit of welly in first,second it ate the coil pack..wow what a bummer...man!!!..but with electrics this does happen....have you coil pack to put on?? Link to post Share on other sites
Bazza1986 0 Posted May 25, 2016 Report Share Posted May 25, 2016 I've had a similar issue, but my cars been sorn due to family issues. Thought a full all round service would do the trick but didn't. I've changed the coil pack, leads and plugs twice since and still the same problem! Low down misfire and judders. Any ideas lads? Link to post Share on other sites
noggin 29 Posted May 31, 2016 Report Share Posted May 31, 2016 I had a similar issue on my old VR6 and the problem stemmed from a faulty Lambda sender. After it had run for ten minutes the catalytic converter was glowing red! Both my VRs have been hard on coilpacks and ht leads. Link to post Share on other sites
matty.vrt 120 Posted June 3, 2016 Report Share Posted June 3, 2016 Best thing I ever did was buy the fattest ignition leads Dubsport do think they were 11mm. Car never missed again. Link to post Share on other sites
