matty.vrt 120 Posted June 30, 2016 Author Report Share Posted June 30, 2016 Made mini looms for injectors and COP's Made using Raychem tefzel wire and DR25 heat shrink. Not the best job ever but it was a learning curve anyways. As long as it works for now I can always spend time later tidying bits up I'm not happy with. VR6Pete 1 Link to post Share on other sites
matty.vrt 120 Posted June 30, 2016 Author Report Share Posted June 30, 2016 Fitted new steering wheel today the old one has done 115,000 miles and is looking rather tired. Removed air bag. What a nightmare to get out, in the end I had to resort to google. OMP 350mm suede WRC with mid dish. Initial reports are feels strange being slightly smaller than standard but the suede is much nicer to touch than the worn polished leather. bennyk 1 Link to post Share on other sites
matty.vrt 120 Posted July 1, 2016 Author Report Share Posted July 1, 2016 Picked up my gearbox from powdercoat today. Not entirely happy with the finish but looks a lot better than it did before. Undecided if I should send it back or leave it as it is. Link to post Share on other sites
matty.vrt 120 Posted July 3, 2016 Author Report Share Posted July 3, 2016 (edited) Just got some pictures of my fuel swirl pot that will be used to feed my belt driven Aeromotive pump. It will be fitted in the hole that used to be occupied by the standard fan intake. P-motorsports alloy fabrication is second to none, just look at those welds Edited July 4, 2016 by matty.vrt VR6CABBS, c00k and RBPE 3 Link to post Share on other sites
VR6CABBS 1,311 Posted July 4, 2016 Report Share Posted July 4, 2016 Just got some pictures of my fuel swirl pot that will be used to feed my belt driven Aeromotive pump. It will be fitted in the hole that used to be occupied by the standard fan intake. P-motorsports alloy fabrication is second to none, just look at those welds Quality bit of kit pal. Link to post Share on other sites
matty.vrt 120 Posted July 4, 2016 Author Report Share Posted July 4, 2016 Thanks VR6CABBS I needed to mount it in a good location so gravity would push the fuel down to the belt pump to avoid cavitation. VR6CABBS 1 Link to post Share on other sites
matty.vrt 120 Posted July 17, 2016 Author Report Share Posted July 17, 2016 Started the big swap yesterday. Firstly I jacked the car up and dropped the oil.Drained the radiator and pulled the front end off. I was not sure the best way to remove the driveshafts but a quick look from underneath revealed that from above would be much easier, so off with the manifolds it was.I then decided to remove all the wires I don't need simply leaving the horns, headlight, reverse sensor and starter wire as I have made a full custom loom for the engine.Next I jacked the back of the car up to remove the full exhaust system.After a couple of hours the engine was finally out.Then I looked to tidy the bay a little. This will be no show car and is being built to be raced so don't expect any fancy tricks. The abs has not worked for a long time and with a lot of track time planned I decided it had to go both for functionality and as it seems heavy a little weight saving too.More updates coming soon as things progress. Link to post Share on other sites
matty.vrt 120 Posted July 18, 2016 Author Report Share Posted July 18, 2016 Clutch came today so I can now mate the engine and gearbox together, happy days Went for Don Octane's flywheel and Sachs RCS200 twin plate clutch good for 1200nm.The flywheel is super light I think the whole assembly weighs less than the standard clutch pressure and friction plate. Link to post Share on other sites
c00k 435 Posted July 19, 2016 Report Share Posted July 19, 2016 Very nice clutch set up! Are you going to go for a harmonic crank pulley aswell? Link to post Share on other sites
Dave_ciw 507 Posted July 20, 2016 Report Share Posted July 20, 2016 Well this escalated quickly hahaha Top work fella and that's a tasty clutch! Link to post Share on other sites
matty.vrt 120 Posted July 20, 2016 Author Report Share Posted July 20, 2016 Very nice clutch set up! Are you going to go for a harmonic crank pulley aswell? Yes I have a fluid dampir already Link to post Share on other sites
matty.vrt 120 Posted July 20, 2016 Author Report Share Posted July 20, 2016 Well this escalated quickly hahaha Top work fella and that's a tasty clutch!Thanks it is a tasty bit of kit and the weight difference compared to the standard dual mass is unbelievable. Dave_ciw 1 Link to post Share on other sites
matty.vrt 120 Posted July 21, 2016 Author Report Share Posted July 21, 2016 More updates keeping this thread fresh.Parts came to upgrade my breaking system to all stainless steel.Now I have flexible stainless back to the master cylinder.Had to ditch the standard brake split to send a single line back to the rear I can control the power with a brake bias valve.Parts came for power steeringMade new line for low pressure side D11PS 1 Link to post Share on other sites
matty.vrt 120 Posted July 21, 2016 Author Report Share Posted July 21, 2016 Engine finally in Mounted turbo manifold just to test the fit.Still need to bolt the driveshafts up but could not resist a look . c00k, VR6CABBS, VR6Pete and 1 other 4 Link to post Share on other sites
matty.vrt 120 Posted July 24, 2016 Author Report Share Posted July 24, 2016 Had another play today. Managed to get a 14mm banjo for the high pressure side of the power steering rack.Bent/ swaged the pipe and sent it into the cabin where my electric PAS pump will be.Found a nice home for my Aeromotive belt drive pump fuel pressure regulator.Fitted two new o rings on the standard plastic water pipe and a new seal on the thermostat housing. I did look at the metal upgrades you can buy but I decided having had VR6 engined cars for the last 9 or so years and never one pipe has failed they are really more about looks than anything else.Then I mounted the front slam panel just to feel like I had done a little more . Link to post Share on other sites
VR6CABBS 1,311 Posted July 24, 2016 Report Share Posted July 24, 2016 It's coming together nicely now pal. There is light at the end of the tunnel. Lol Link to post Share on other sites
Dave_ciw 507 Posted July 26, 2016 Report Share Posted July 26, 2016 Absolutely killing it fella! Top notch work! Link to post Share on other sites
matty.vrt 120 Posted July 26, 2016 Author Report Share Posted July 26, 2016 Just can't wait to get the thing started. Dave_ciw 1 Link to post Share on other sites
matty.vrt 120 Posted August 2, 2016 Author Report Share Posted August 2, 2016 Managed to get an 11" Spal pull fan mounted to my radiator today using the supplied 'quick connect kit' Apologies for my terrible fabrication skills, made a bracket today to mount my 19 row oil cooler to my 52mm twin pass polo radiator.This is how it will sit. Just need to make some mounting brackets for the entire assembly. On the plus side the new rad, fan & oil cooler weighs at least 50% lighter than the old rad, fan & air con radiator. D11PS 1 Link to post Share on other sites
VR6CABBS 1,311 Posted August 2, 2016 Report Share Posted August 2, 2016 Now that's gonna be a good fit mate. Nice bit of work. Link to post Share on other sites
matty.vrt 120 Posted August 4, 2016 Author Report Share Posted August 4, 2016 Made some brackets to mount the radiator the other day. I wanted to try and add a bit of a quality look so I drilled a few extra holes, not perfect but will work for me. Link to post Share on other sites
matty.vrt 120 Posted August 5, 2016 Author Report Share Posted August 5, 2016 Turbo mounted Positioned the charge cooler so I can start mocking up the pipework. Dave_ciw, c00k and JakeP 3 Link to post Share on other sites
Dave_ciw 507 Posted August 6, 2016 Report Share Posted August 6, 2016 Lovely! Looking great mate. matty.vrt 1 Link to post Share on other sites
matty.vrt 120 Posted August 12, 2016 Author Report Share Posted August 12, 2016 After spending ages trying to work out where I should mount the race battery I have finally found a neat location. I knew I wanted to mount it in the cabin to make more room in the engine bay and for weight distribution it had to be on the passenger side.Rear quarter panel it is then. Link to post Share on other sites
matty.vrt 120 Posted August 12, 2016 Author Report Share Posted August 12, 2016 Belt drive fuel pump all piped up with E85 friendly Aeromotive fuel filter. VR6Pete, J4Y VR and palmer 3 Link to post Share on other sites
