Mods for N/A vr6 12v
Hi there. Just wanted to find out from people with experience in N/A mods for the vr6. Iv got a mk3 golf 2.8 12v vr6. Want to do a few upgrades to get the max out the motor without changing or fiddling with the ECU.. as we all know the vr6 is abit sluggish on the bottom end when left standard... thanks
how much are you spending? its all about money.
cheap
Audi 1.8T Air intake temp sensor (standard is in block and gets heat soaked) rewire to cooler area maybe inside airbox?
airbox mod -  drill huge holes or cut the bottom of the air box out
DIY port head and throttle body
panel filter
medium 250-1000
install  new cams 263's 267's etc
ported and big valve head
3.67 final drive (no power but better gearing, would look to do diesel 5th gear for better cruising) also if gearbox is off lightweight flywheel and chains
2nd hand charger?
new or 2nd hand exhaust
expensive £1000 up
super charger (easy to put back to original)
turbo (can be expensive but HUGE fun)
r32/r36 engine swap
No real gains will be made without 'fiddling' with the ecu.
The best value for money is in a C2/UM chip tune, fueling kit and a cheap turbo conversion.
It can be done all in for £1000 - £2500 and returns will be around 300 - 400bhp and many smiles per miles.
N/A tuning is money down the drain on a VR6 as the return on investment is simply does not add up.
Again, NA tuning is expensive, spent close to £1000 completely reconditioning the head, new cams, valves, seals etc
Few things you could to change the "feel" though
In the states the use MK4 12v VR6 head gasket as appose to the MK3 one, slight increase in gains and increased compression
Also a lightened flywheel will change how it will drive along with MK4 V5 gearbox.
cheap
panel filter
medium 250-1000
2nd hand charger?
expensive £1000 up
r32/r36 engine swap
Just out of interest, which cams are good.. Autotech, Schimmel, Schrick etc..?
cheap
panel filter
medium 250-1000
2nd hand charger?
expensive £1000 up
r32/r36 engine swap
1 hour ago, ssaunders said:
All those makes are fine, it's what you want from them. 263's are good especially with FI. 267's work higher in the rev range and work well with a schrick mani and its normal I believe to uprate the retainers to allow higher revving.
Thanks for that, I was looking at the Autotech 262's so will probably go with those... ;)
  • 3 years later...
hey wena fuseg man
