arbroathautospar 15 Posted September 4, 2016 Report Share Posted September 4, 2016 Hi just wondering if anyone has had a similar problemMy 1994 golf vr6 just came out the garage after a lot of mods have been done did 200 miles in it no problem then out for a wee blast and it shut down no fuel had to get towed home did a couple of checks with bulb tester tryed starting the car to check power at the pump and it started and has been fine but don't want to take it to far just in case Link to post Share on other sites
ssaunders 199 Posted September 4, 2016 Report Share Posted September 4, 2016 Hi, if it's odb2 any fault codes? Has the ecu been chipped after the mods? s Link to post Share on other sites
arbroathautospar 15 Posted September 4, 2016 Author Report Share Posted September 4, 2016 Nah it's obd 1 with a socketed ecu which was in before the mods need to have a new chip done was told it was a stealth chip but don't know Link to post Share on other sites
arbroathautospar 15 Posted September 4, 2016 Author Report Share Posted September 4, 2016 I have put a6 branch manifold mated to a full milltek decat Cda carbon airbox l/balanced flywheel stage 2 clutch 50mm alloy rad silicone hose set Done away with original intake to manifold Replaced everything with silicone as I say it was going like a train I thought the fuel pump had gone but it's now working all tho changes pitch on idle only thing I haven't replaced on it Link to post Share on other sites
arbroathautospar 15 Posted September 4, 2016 Author Report Share Posted September 4, 2016 Link to post Share on other sites
ssaunders 199 Posted September 4, 2016 Report Share Posted September 4, 2016 Here is a link to read odb1 codes. Might be worth a go? http://www.a2resource.com/electrical/codes/vr6.html Link to post Share on other sites
arbroathautospar 15 Posted September 4, 2016 Author Report Share Posted September 4, 2016 Cheers bud I will give it a check I originally put coilovers on it when I built it but changed them for konis after things started shaking loose wouldn't suprise me to find that something has ce loose in the tank haha Link to post Share on other sites
arbroathautospar 15 Posted September 25, 2016 Author Report Share Posted September 25, 2016 Hi guys I have plugged the car in with vagcom and hav got fault code saying engine blocked by immobiser however my car doesn't have an vw immobiser but the original ecu was swapped out for a socketed ecu.The car starts and drives but don't want to go to far in it in case it does the same again would this fault come up as a fault if the ecu has had immobiser defeat done anyone know Cheers Link to post Share on other sites
boab3 164 Posted September 25, 2016 Report Share Posted September 25, 2016 Can only mean obd2 as obd1 wasn't immobilised. Link to post Share on other sites
boab3 164 Posted September 25, 2016 Report Share Posted September 25, 2016 Sorry my mistake if it's an early vr it's not got an immobiliser some of the later obd1 do have immobiliser Link to post Share on other sites
VR6Pete 1,455 Posted September 25, 2016 Report Share Posted September 25, 2016 That's correct. My 1994 Corrado was obd1 and had factory imob. First thing to check is the wiring from coil reader to alarm box. Sometimes just needs cleaning etc.. the whole imob system are prone to going down and simply best thing to do is to code out the ECU. Send it to stealth racing they will do it on a 48hour turn around. Link to post Share on other sites
arbroathautospar 15 Posted September 26, 2016 Author Report Share Posted September 26, 2016 Cheers guys but plot thickens I went round the town in the car good half hour of driving car was sweet as a nut pulling like a Trojan bogs down a bit at low end (flywheel is too light I was warned ha) but after nipping about came to a roundabout and it cut out and wouldn't start no fuel coming through power at the tank .Left it for 3 hours went to tow it back and it started off the button and drove home sweet did the early obd 1 cars immobiser kill the fuel pump? I have checked the key and doesn't appear to have any transponder in it it also has a laserline alarm which does kill the pump but appears to be working ok any help would be appreciated as I can't get my head round this cheers Link to post Share on other sites
arbroathautospar 15 Posted September 26, 2016 Author Report Share Posted September 26, 2016 Sorry mine is a 1994 obd1 golf vr6 Link to post Share on other sites
boab3 164 Posted September 26, 2016 Report Share Posted September 26, 2016 109 relay common problem with fuel pump issues.but I'd be bypassing alarm incase it's randomly immobilising pump Link to post Share on other sites
VR6Pete 1,455 Posted September 26, 2016 Report Share Posted September 26, 2016 3 hours ago, arbroathautospar said: Cheers guys but plot thickens I went round the town in the car good half hour of driving car was sweet as a nut pulling like a Trojan bogs down a bit at low end (flywheel is too light I was warned ha) but after nipping about came to a roundabout and it cut out and wouldn't start no fuel coming through power at the tank . Left it for 3 hours went to tow it back and it started off the button and drove home sweet did the early obd 1 cars immobiser kill the fuel pump? I have checked the key and doesn't appear to have any transponder in it it also has a laserline alarm which does kill the pump but appears to be working ok any help would be appreciated as I can't get my head round this cheers If there is no transponder in the key, check to see if its been secured to the pickup around the ignition barrel. If the imob has been bypassed in the past (defeated as its some times referenced as) then you will still get the "Engine start blocked by immobilizer" error, if when it starts OK and you DONT get the error, then suggests it has not been bypassed and you have a genuine intermittent fault, in which case you would only get engine start blocked by immobilizer error when it has been blocked by imob due to a fault. Side thought though - does this happen from cold / I.E when standing and not a hot start issue? and when it cools down car starts again? if so, possible crank sensor. but If it happens from cold then would suggest to be 100% imob related, but as @boab3 says, replace 109 relay as also common issue. Link to post Share on other sites
arbroathautospar 15 Posted September 26, 2016 Author Report Share Posted September 26, 2016 It runs perfect when cold only appears to be once it has been driven for a while that it cuts out I am thinking the pump is faulty as I have checked the power going to the pump and it's fine after the car has sat for a few hours it starts again Link to post Share on other sites
boab3 164 Posted September 26, 2016 Report Share Posted September 26, 2016 I'd be tempted to change relay 109 I think it's position number 3 in fusebox they have a habit of failure VR6Pete 1 Link to post Share on other sites
arbroathautospar 15 Posted September 26, 2016 Author Report Share Posted September 26, 2016 Cheers mate I will give that a try but when I checked power at fuel pump while it wouldn't start the power was there so if the relay was faulty it wouldn't have power at the pump surely? Link to post Share on other sites
boab3 164 Posted September 26, 2016 Report Share Posted September 26, 2016 Power at pump and still not starting can only be pump did you check earth at pump plug as well Link to post Share on other sites
CozzPheonix 0 Posted October 14, 2021 Report Share Posted October 14, 2021 Hi! Wondering if this has been solved? Seem to have the exact same issue on my Vr6, obd 1, old alarm system has been removed. Once it's been running for 30 mins ish will cut out, starts up again fine 10 mins later or sometimes with a bit of throttle. Replaced the relay so thinking must be fuel pump failing? Link to post Share on other sites
