boab3 164 Posted January 9, 2017 Author Report Share Posted January 9, 2017 Still pipework and catch can to do then fit mk3 tank for fuelling.just small snags weird how my charger pulley is only 6 groove.i got hold of a mk4 aircon pump on flea bay for £10 that was including delivery i removed pulley took of magnetic clutch and fitted new bearing into my 7 rib pulley and built that up it fits well and seriously light now since removal of magnet Link to post Share on other sites
boab3 164 Posted January 10, 2017 Author Report Share Posted January 10, 2017 Silicone hoses or aluminium pipe work? Any recommendations Link to post Share on other sites
VR6Pete 1,455 Posted January 10, 2017 Report Share Posted January 10, 2017 8 minutes ago, boab3 said: Silicone hoses or aluminium pipe work? Any recommendations I got all mine my alloy pipework and silicon from http://www.autosiliconehoses.com/ boab3 1 Link to post Share on other sites
boab3 164 Posted January 11, 2017 Author Report Share Posted January 11, 2017 Fits nicely just have to drop engine back onto mounting then pipe up Link to post Share on other sites
boab3 164 Posted January 11, 2017 Author Report Share Posted January 11, 2017 Why has taptalk disabled pictures? VR6Pete 1 Link to post Share on other sites
VR6Pete 1,455 Posted January 11, 2017 Report Share Posted January 11, 2017 Why has taptalk disabled pictures?It's a bug. Use the paper clip icon to upload instead of the photo icon. Currently being investigated and fixed boab3 1 Link to post Share on other sites
boab3 164 Posted January 20, 2017 Author Report Share Posted January 20, 2017 Struggling finding anything near this 90 degree elbow its a 90 degree offset elbow can only find a standard 90 degree elbow Link to post Share on other sites
VR6Pete 1,455 Posted January 20, 2017 Report Share Posted January 20, 2017 cant you get 2x 90 degree with a alloy joiner? Link to post Share on other sites
boab3 164 Posted January 20, 2017 Author Report Share Posted January 20, 2017 cant you get 2x 90 degree with a alloy joiner?Yeah my only option but i was hoping for less joints less clutter of jubilee clips. Link to post Share on other sites
boab3 164 Posted January 20, 2017 Author Report Share Posted January 20, 2017 Not much clearance but we're in Link to post Share on other sites
VR6Pete 1,455 Posted January 20, 2017 Report Share Posted January 20, 2017 45 minutes ago, boab3 said: Yeah my only option but i was hoping for less joints less clutter of jubilee clips. oh ok - try emailing that photo of what you want to merlin motorsport - they may be able to provide the samco part number Link to post Share on other sites
VR6CABBS 1,311 Posted January 20, 2017 Report Share Posted January 20, 2017 oh ok - try emailing that photo of what you want to merlin motorsport - they may be able to provide the samco part numberOr email Samco direct and they will supply a stockist near you. Link to post Share on other sites
boab3 164 Posted January 20, 2017 Author Report Share Posted January 20, 2017 Hoses ordered guys cheers anyway.here Monday hopefully hear a bit of boost by next week. Link to post Share on other sites
boab3 164 Posted January 26, 2017 Author Report Share Posted January 26, 2017 Not mine but exactly the same charger.as my outlet of the snail housing is slightly off to where i would like it to be would anyone know if id have any problems moving snail housing round half a hole as in picture the housing has more holes than required so i want to rotate housing only to the next hole back.i can't see there being a problem but any advice appreciated VR6Pete 1 Link to post Share on other sites
boab3 164 Posted January 27, 2017 Author Report Share Posted January 27, 2017 Sorted now turned snail round a bit and hoses fitting not bad VR6 Supercharged and VR6Pete 2 Link to post Share on other sites
VR6Pete 1,455 Posted January 27, 2017 Report Share Posted January 27, 2017 I had to do some messing with mine and rotate the snail. A proper pain pain in the ass ? VR6 Supercharged and boab3 2 Link to post Share on other sites
boab3 164 Posted January 27, 2017 Author Report Share Posted January 27, 2017 Oil catch can to source squeeze in maf and filter somewhere.had to take oil bath off had nipped o ring when fitted so new o rings all leak free now VR6Pete 1 Link to post Share on other sites
VR6Pete 1,455 Posted January 27, 2017 Report Share Posted January 27, 2017 41 minutes ago, boab3 said: Oil catch can to source squeeze in maf and filter somewhere.had to take oil bath off had nipped o ring when fitted so new o rings all leak free now Theres not much room anywhere with a charger on ? Good bye knuckles. this is where I keep mine VR6 Supercharged and boab3 2 Link to post Share on other sites
boab3 164 Posted January 28, 2017 Author Report Share Posted January 28, 2017 Theres not much room anywhere with a charger on Good bye knuckles. this is where I keep mineThats a long inlet pipe before charger.is there a set distance the maf should be away from the turbulence from the impeller Link to post Share on other sites
VR6Pete 1,455 Posted January 28, 2017 Report Share Posted January 28, 2017 9 hours ago, boab3 said: Thats a long inlet pipe before charger.is there a set distance the maf should be away from the turbulence from the impeller Minimum 18" on vortech. May not be as bad on the z engineering mine. The key was to get an "s" shape could have got smaller length in but certainly doesn't hurt..: unless you drive through flood water ? Then it sucks like a dyson V6 haha so think ahead with position. Link to post Share on other sites
boab3 164 Posted February 10, 2017 Author Report Share Posted February 10, 2017 Cant beat a bargain nice morning for purchasing this rare eibach strut brace for my mk2 brand new £38 fleabay has made my day VR6 Supercharged 1 Link to post Share on other sites
boab3 164 Posted February 11, 2017 Author Report Share Posted February 11, 2017 Tight but im fitted upOld chip out new chip in ready to fire up Link to post Share on other sites
boab3 164 Posted February 12, 2017 Author Report Share Posted February 12, 2017 Well got round to starting up didnt fire as normal very rough wont idle.smooth on throttle tho.lamda fault came up on vagcom so new lambda to go on.and still a leak from oil bath cant seem to get this leak sorted yeti thought i had it sorted but still a run from bath and its from the bath seals not the inner seals annoying but slow progress.but charger has a nice whistle sounds spot on VR6 Supercharged and VR6Pete 2 Link to post Share on other sites
VR6Pete 1,455 Posted February 13, 2017 Report Share Posted February 13, 2017 Possible air leak ? Maf too close to charger? Took a bit get mine running nice. But was just unmetered air in the end. What is needed fix leak on oil bath? I'm not familiar with how these work boab3 1 Link to post Share on other sites
boab3 164 Posted February 13, 2017 Author Report Share Posted February 13, 2017 Im wondering if lambda would affect the idling as i did have a few niggles previously and my april mot last year just made it on its emissions the co was at maximum limit so i think its maybe now with bigger injectors new chip and a faulty lambda its chucking a lot of fuel in there.As for the oil bath I'll have to take charger off again have a good inspection see whats happening where oil leak is coming from.But on a good note its sounding nice under a bit of throttle.Only 1 other thing ive done is delete isv and blanked pipe Link to post Share on other sites
