Goodge123 5 Posted November 5, 2016 Report Share Posted November 5, 2016 Started to strip the engine down ready to rebuild . Took the head off and found lots off corrosion caused by coolant . I was taking the head off to give it a skim before putting a new head gasket on. Any opinions if this head is ready for the skip or will it still live Link to post Share on other sites
stephencarmichael118@gmail 3 Posted November 5, 2016 Report Share Posted November 5, 2016 if iam honest I would see what allowances you have between valves and pistons 25 thou would be the most I would go sorry if that not much help Link to post Share on other sites
Goodge123 5 Posted November 5, 2016 Author Report Share Posted November 5, 2016 If you mean skim it to remove the corrosion it would need 2 to 3 mill off of it dbaboon 1 Link to post Share on other sites
VR6Pete 1,455 Posted November 8, 2016 Report Share Posted November 8, 2016 Wow, yes looks like 90% of VR6 heads you see today! a little corrosion is normal for these old girls..... I have seen similar repairs with JB weld or equivalent to fill in the void - after all the head gasket will compress it back again. get whole headed dipped and cleaned, repair corrosion, and get skimmed should be job done, alternatively look on our classifieds for other second hand heads in better condition but I can tell you most heads will be like that this day and age rich 1 Link to post Share on other sites
Goodge123 5 Posted November 10, 2016 Author Report Share Posted November 10, 2016 Going to weld the head up . Vapour blast it then skim it. Don't want to skim loads of as I was going to fit a mk4 head gasket to up it to 10.5 comp ratio VR6Pete 1 Link to post Share on other sites
VR6Pete 1,455 Posted November 10, 2016 Report Share Posted November 10, 2016 Best way to go really, skim as little as you need, no more rich 1 Link to post Share on other sites
rich 40 Posted November 11, 2016 Report Share Posted November 11, 2016 spot on...youd be surprised what a blast and skim will do to clean that up,like vr6pete said most will be in that condition or worse nowadays..good luck!! VR6Pete 1 Link to post Share on other sites
