Godlexxx 1 Posted November 10, 2016 Report Share Posted November 10, 2016 Hi all im new to this club and need some solid advice urgently. I have a 95 mk3 vr6 golf,which im busy turboing.i am a diesel mechanic by profesion so i have good knowledge of cars. Theres my setup thus far.. T3/t04e 50 trim cold side, .82 a/r hotside Turbo smart 1:1 rising fuel regulator Twin 34mm forge reciculating valves 50mm hks style waste gate Custom 2.5" stailess steel downpipe 2.5" stainless steel freeflow exhaust system Oil catch can,manual boost controler Custom 3" cold induction with k&n filter,front mount intercooler with 2.5" stainless boost pipes Custom exhaust turbo mani Ok heres the deal im finishing the built this weekend and wantef to drive a bit.. With stock fuel pump,injectors,ecu and rrfpr whats the max safe boost i can run on stock botom end and stock compression if i crank up fuel pressure and to what pressure should i crank it up. i just want to see how she goes,will be locking boost at 5 psi till next month when i do 320l intank fuel pump and stanalone ecu. thanx in advance. Link to post Share on other sites
Godlexxx 1 Posted November 10, 2016 Author Report Share Posted November 10, 2016 Forgot to mention,my stock regulator is 3bar and i have a custom short intake mani as well.. Link to post Share on other sites
al_mooring 102 Posted November 11, 2016 Report Share Posted November 11, 2016 Should be fine at 5psi but please have a AFR/lambda and boost gauge minimum to keep an eye on things as the standard Ecu will only go so far if you are not mapping itWhen you are going standalone ditch the recirc valves and go for a BOV as you can ditch the MAF sensor. I would then run something like 630's with an inline 044 or intank 040 pump to safe guard your fuelling Link to post Share on other sites
Godlexxx 1 Posted November 11, 2016 Author Report Share Posted November 11, 2016 Thanx a lot friend,will try to get a wideband kit.. im only looking for 260-300 whp,will that be ok for the stock tranny and clutch set up? nex year will be doing decomperssion spacer,440 injectors,arp top and rod bolts. do you perhaps know at what rpms i will start seeing boost with this setup? Godwin Link to post Share on other sites
kaashifmann 8 Posted November 15, 2016 Report Share Posted November 15, 2016 I ran 7 psi stock ecu an injectors, with fuel pressure turned up, they don't like it, so I went all out stand alone and custom everything pretty much it never ends Godlexxx 1 Link to post Share on other sites
Godlexxx 1 Posted November 16, 2016 Author Report Share Posted November 16, 2016 I think i'll just wait for the standalone ecu,will have it in about 2 weeks time... i was wondering what you guys think of the ngk bkr6e plugs as in my country i cant seem to find bkr7e plugs,and also what thickness is the middel part of the head spacer that a lot of guys are using to get to 9.0:1 compression ratio? thanx a lot for the replies so far. want to upload some pics but have problems in doing so kaashifmann 1 Link to post Share on other sites
kaashifmann 8 Posted November 16, 2016 Report Share Posted November 16, 2016 Not sure on the plugs, but I'm running the c2 headspacer, an to get the correct thickness you use the mk4 metal gasket, u split the gasket by drilling the rivets out an sandwich the spacer with the outer layers of the gasket which give you the correct Comp ratio an creates a head gasket seal. Hopefully this makes sense lol Godlexxx 1 Link to post Share on other sites
Godlexxx 1 Posted November 16, 2016 Author Report Share Posted November 16, 2016 Thanx bro,i think ill get a 2mm midell layer machined and just add the top and bottom halfs of mk4 gasket... just curious as to if arps are really needed.. i plan to run max 0.5 bar stock bottom end,standalone ecu,1 step colder plugs and front mount intetlcooler,want to step it up to about 0.8 bar once decompression plate is on. you think that will be safe? Link to post Share on other sites
