perrone123 2 Posted November 22, 2016 Report Share Posted November 22, 2016 ive been looking at the threads before posting this and I cant find the answer I recently purchased a 2000 mk4 jetta vr6 its very clean but one problem its automatic. yes I know its cheaper too buy one that already Manuel but I want to have some fun!. my question is. if I were to replace the auto ecu with a Manuel ecu with the matching cluster would I still have to do additional wiring. please help! if I do please tell what I would have to do. Link to post Share on other sites
zipupurmickey 7 Posted November 22, 2016 Report Share Posted November 22, 2016 You would also need the imob from the key the new ecu came from. I presume you've got the Man gearbox, and pedal box etc ready too? perrone123 1 Link to post Share on other sites
perrone123 2 Posted November 22, 2016 Author Report Share Posted November 22, 2016 Yes sir I do Link to post Share on other sites
perrone123 2 Posted November 22, 2016 Author Report Share Posted November 22, 2016 But can I keep the auto harness inside and plug the Manuel ecu and cluster without and problems Link to post Share on other sites
perrone123 2 Posted November 22, 2016 Author Report Share Posted November 22, 2016 You would also need the imob from the key the new ecu came from. I presume you've got the Man gearbox, and pedal box etc ready too?Yes sir I do but can I keep the auto harness and plug the Manuel ecu and cluster with no problems ? Link to post Share on other sites
milos24v 3 Posted November 26, 2016 Report Share Posted November 26, 2016 Why you just cannot switch to a manual gearbox, and just remove wiring and ecu for a gearbox? I'm asking it because I have ecu and wiring from automatic and swapped it in mk2 golf with manual tranny. Link to post Share on other sites
milos24v 3 Posted November 27, 2016 Report Share Posted November 27, 2016 I just read that it's possible to get a reflash to your auto ECU to works on manual tranny. perrone123 1 Link to post Share on other sites
perrone123 2 Posted November 27, 2016 Author Report Share Posted November 27, 2016 I just read that it's possible to get a reflash to your auto ECU to works on manual tranny. What company does that? So I can't use my ecu from my donor car ? Link to post Share on other sites
milos24v 3 Posted November 27, 2016 Report Share Posted November 27, 2016 http://nefariousmotorsports.com/forum/index.php?action=printpage;topic=1843.0I can't give you more info untill I speak with a men who is going to work on mu wiring. So as soon as I find out something, I'm going to write it here. Cheers. perrone123 1 Link to post Share on other sites
perrone123 2 Posted November 28, 2016 Author Report Share Posted November 28, 2016 http://nefariousmotorsports.com/forum/index.php?action=printpage;topic=1843.0I can't give you more info untill I speak with a men who is going to work on mu wiring. So as soon as I find out something, I'm going to write it here. Cheers.Thanks a lot excited to hear Link to post Share on other sites
milos24v 3 Posted November 28, 2016 Report Share Posted November 28, 2016 The ECU usually doesn't allow simple recoding, in most cases it's nessesary to remap it with manual ECU map. That is just guessing, we'll find out when I take a car to his garage in two weeks... I'll get back with results... Link to post Share on other sites
perrone123 2 Posted November 29, 2016 Author Report Share Posted November 29, 2016 The ECU usually doesn't allow simple recoding, in most cases it's nessesary to remap it with manual ECU map. That is just guessing, we'll find out when I take a car to his garage in two weeks... I'll get back with results...So I took the eCU from the donor car and placed it into the project car The bigger connecter cannot fit into the manual ECU. of course this is the original harness the automatic one, is it possible for me to break off that piece so it would fit into the connecter or does this mean I have to change harnesses sorry if I sound very stupid but it looks like it could be done because the other connecter from the donor car looks exact same as the automatic one just has two different adaptors VR6Pete 1 Link to post Share on other sites
milos24v 3 Posted December 1, 2016 Report Share Posted December 1, 2016 I'm not sure, it's there for a reason. You should consult someone who tried this, if you don't wanna burn it. perrone123 1 Link to post Share on other sites
