Pjc 2 Posted January 2, 2017 Report Share Posted January 2, 2017 Hi,After advice for problem solving of starting issue when engine warm.Engine starts fine when cold but has just started in the last week to not restart easily when warm. If left for a short while it fires up fine.Any advice is most welcome. Link to post Share on other sites
mattvr6 133 Posted January 2, 2017 Report Share Posted January 2, 2017 Temp sensor Link to post Share on other sites
VR6Pete 1,455 Posted January 2, 2017 Report Share Posted January 2, 2017 Also check out crank position sensor. They can break down when hot and cause similar problems as you describe. Link to post Share on other sites
mattvr6 133 Posted January 2, 2017 Report Share Posted January 2, 2017 Never replaced a crank sensor on a vr, code read would point you in the right direction Link to post Share on other sites
Pjc 2 Posted January 3, 2017 Author Report Share Posted January 3, 2017 Thanks for replies. I will get these looked at sometime in the next few days. Link to post Share on other sites
Pjc 2 Posted January 12, 2017 Author Report Share Posted January 12, 2017 Changed the temp sensor at the weekend and got the ecu checked and error code for temp sensor cleared. Everything seems ok now. Link to post Share on other sites
