dubspy 19 Posted January 3, 2017 Report Share Posted January 3, 2017 Hi all, Does anyone have a wiring diagram for the fans on a obd2 vr6. Someone in the past has added a permanent live and i would like to put it back to factory so it is not running all the time. Thank you Link to post Share on other sites
VR6Pete 1,455 Posted January 3, 2017 Report Share Posted January 3, 2017 Do you know where the 12v feed is going too? I would suggest that there is a fault which is why a direct 12v feed has been put on. FCM, Temp Sensor, Rad switch possible causes. Bentley manual will have wiring diagrams - https://drive.google.com/file/d/0ByZN3kG9R6E3dkNBbWpqcnNjdnM/view?pli=1 Link to post Share on other sites
dubspy 19 Posted January 3, 2017 Author Report Share Posted January 3, 2017 (edited) hi Mate, i haven't had a look at it yet, wanted to get a diagram before looking into it. Will have a look and get back to you. Thank you for the info Edited January 3, 2017 by dubspy Link to post Share on other sites
Philly-R6 28 Posted January 3, 2017 Report Share Posted January 3, 2017 Try searching t'internet for g3radfan3speed.pdf, and you should find a two page PDF containing a wiring diagram. I've not checked it (some wiring diagrams do have errors in them), but it seems ok on the whole... There is a cool thread on the Corrado forum describing the cooling system, which may be worth a read: http://the-corrado.net/showthread.php?38925-The-definitive-VR6-cooling-guide ssaunders 1 Link to post Share on other sites
ssaunders 199 Posted January 4, 2017 Report Share Posted January 4, 2017 (edited) ^^^^^^ great response the Corrado forum link is excellent at diagnosing issues, i would ask why it was bypassed initially? here is the gr3radfan pdf g3radfan3speed.pdf Edited January 4, 2017 by ssaunders Link to post Share on other sites
dubspy 19 Posted January 4, 2017 Author Report Share Posted January 4, 2017 Thanks for the replies, i was sent that wiring diagram on another forum and is spot on and just what i was looking for. Thanks for all the help guys Link to post Share on other sites
