VOSWAGGINVR6 7 Posted February 12, 2017 Report Share Posted February 12, 2017 Hello everybody been awhile since I posted. I just picked up a jetta glx been sitting awhile. Anyways I've put jumper cables on it to start it but no luck everything seems normal except when I turn the key on. I don't get any dash lights like the back light and warning lights and also the abs light beside the light switch is on. The radio sound like it's only playing through tweeters. And one more thing if I have the switch on the miles and time are displaying but if I turn head lights on they get faded. Any ideas or help will be appreciated. Thanks.. Bob. Link to post Share on other sites
Stephen Bevan 3 Posted February 12, 2017 Report Share Posted February 12, 2017 Sounds like bad earthing, check the earth cables that a joined to the chassis some time the cables and connections rust Link to post Share on other sites
VOSWAGGINVR6 7 Posted February 12, 2017 Author Report Share Posted February 12, 2017 Sounds like bad earthing, check the earth cables that a joined to the chassis some time the cables and connections rust Under the battery tray. Correct. Link to post Share on other sites
Stephen Bevan 3 Posted February 12, 2017 Report Share Posted February 12, 2017 Under the battery tray. Correct.There's other earthing points as well, behind the dash ect if the current can't pass to earth through the earth points then it takes another route through other components Link to post Share on other sites
VOSWAGGINVR6 7 Posted February 12, 2017 Author Report Share Posted February 12, 2017 Would you happen to know where at the doors don't lock either Link to post Share on other sites
Stephen Bevan 3 Posted February 12, 2017 Report Share Posted February 12, 2017 Would you happen to know where at the doors don't lock eitherDon't they lock with the key? If not then they might need a new barrel or a whole new locking mechanism Link to post Share on other sites
VOSWAGGINVR6 7 Posted February 12, 2017 Author Report Share Posted February 12, 2017 Just driver door locks but other three stay unlocked. Alarm goes off every now and then. When I put key in switch it acts like the switch isn't working when I turn it on but abs light comes on Link to post Share on other sites
Stephen Bevan 3 Posted February 12, 2017 Report Share Posted February 12, 2017 Just driver door locks but other three stay unlocked. Alarm goes off every now and then. When I put key in switch it acts like the switch isn't working when I turn it on but abs light comes onIt's probably the central locking pump has gone, on the golfs there in the boot near the drivers side light it's normally in a foam case they are known for going the seal in the back light perishes and water corrodes the connector there about £15/£30 on eBay just make sure you sort the light gasket out first, and it could be a faulty ignition switch, it might be worth getting an auto electrician out to take a look at it Link to post Share on other sites
VOSWAGGINVR6 7 Posted February 12, 2017 Author Report Share Posted February 12, 2017 Ok Link to post Share on other sites
VOSWAGGINVR6 7 Posted February 14, 2017 Author Report Share Posted February 14, 2017 The starting problem was due to the ignition switch. Only problems I have now is no dash lights, no warning lights (check engine,airbag, etc) and my doors won't lock only driver door from outside but have yet to find central locking pump. Link to post Share on other sites
Stephen Bevan 3 Posted February 14, 2017 Report Share Posted February 14, 2017 I wonder if your pump is missing, is the a black or red pipe near one of your rear light clusters and a bunch of wires, have you checked all your fuses and relays,For your dash?, does the abs and airbag light block come out? I remember I unplugged mine and some of the dash lights wasn't working Link to post Share on other sites
VOSWAGGINVR6 7 Posted February 14, 2017 Author Report Share Posted February 14, 2017 I got locks to work pump was froze up. But still no dash lights and the radio is still high pitch Link to post Share on other sites
Stephen Bevan 3 Posted February 14, 2017 Report Share Posted February 14, 2017 Sounds like it could be a bad earth somewhere behind the dash Link to post Share on other sites
VOSWAGGINVR6 7 Posted February 14, 2017 Author Report Share Posted February 14, 2017 I'll check again but everything looked good Link to post Share on other sites
VOSWAGGINVR6 7 Posted March 25, 2017 Author Report Share Posted March 25, 2017 Doors lock now but I'm still having trouble with my cluster still no warning lights I'm so confused I've tried a lot . cleaned all grounds inter changed parts and still nothing. But if the battery is hooked up for about 10 15 mins the horn will beep then alarm goes off. Any help will be appreciated Link to post Share on other sites
