Edmonzo 0 Posted July 4, 2005 Report Share Posted July 4, 2005 Has anyone got a "How To" on removing and fittig a coil pack on a '95 olf VR? Mine has been doing the chuggy thing and I've just tested it by spraying fine mist on the coil pack while it's running and there were sparks outside of the pack. !sad Also, can anyone recommend somewhere to buy the coil pack other than the dealers?Thanks Guys. Link to post Share on other sites
mightyvr6 0 Posted July 4, 2005 Report Share Posted July 4, 2005 GSF car parts ell them for Link to post Share on other sites
Edmonzo 0 Posted July 4, 2005 Author Report Share Posted July 4, 2005 Cheers MightyVr6, i'll try GSF car parts. there appeared to be a few cracks so I think I'll just go for a new one. Link to post Share on other sites
Eat this 2 Posted July 4, 2005 Report Share Posted July 4, 2005 siliocone sealent is also good Link to post Share on other sites
Edmonzo 0 Posted July 4, 2005 Author Report Share Posted July 4, 2005 Sorry to sound stupid but is this what i'm looking for??92526 IGNITION COIL/TRANSFORMER G3 VR6 AAA Eng. (Ch.1HP W1480001>) -Distributor Link to post Share on other sites
Eat this 2 Posted July 4, 2005 Report Share Posted July 4, 2005 sorry silicone would do a decent tempory repair Link to post Share on other sites
mightyvr6 0 Posted July 4, 2005 Report Share Posted July 4, 2005 Looks right. Seriously though try coating the plastic with epoxy as the sparking is caused by hairline cracks in the plastic which causes arcing. Coilpacks rarely fail (my original coilpack is on 126,000) and the repair will make it work perfectly. It's only when one of the coil fails that you'd need a new one so it's defo worth doing the repair. Link to post Share on other sites
binliner 0 Posted July 4, 2005 Report Share Posted July 4, 2005 what he said!If you do change it it's a doddle to do... just unplug the connector and leads and then theres a bolt in each corner to undo... do the reverse ti fit the new one and job done Link to post Share on other sites
Edmonzo 0 Posted July 4, 2005 Author Report Share Posted July 4, 2005 Cheers guys, I'll give the epoxy a go - I've got nothing to lose. Thanks for all your help/suggestionsEd Link to post Share on other sites
Edmonzo 0 Posted July 5, 2005 Author Report Share Posted July 5, 2005 Went to B&Q and they only had normal epoxy resin and hardener - not the high temperature stuff. The only stuff I could see that was water proof and okay up to 120oC was some super glue called EXTREME. Do you reckon this would be the same or is it just the epoxy that I need? Link to post Share on other sites
