motorrob 15 Posted June 24, 2017 Report Share Posted June 24, 2017 Seen these powertrack inserts for the haldex systems. Which constantly applies the rear so it's 50/50 split constantly. And for 60 quid lot cheaper than a haldex controller. Anyone ever used one of these ? Good /bad? Link to post Share on other sites
motorrob 15 Posted July 31, 2017 Author Report Share Posted July 31, 2017 Well went for it and got myself one,Thought I'd try it. changed haldex oil and filter at the same time. Awsome difference taking her out for the first time. gives you confidence and feels more planted. Feels really smooth also, was expecting it to be really harsh. Link to post Share on other sites
ssaunders 199 Posted August 1, 2017 Report Share Posted August 1, 2017 Hi, Road or Track? any binding when turning or reversing? as its 50/50 all the time are you expect the fuel consumption to go up? my Rado is being converted from Syncro to Haldex by the phirm and i have been looking for a controller although they think they can come up with something, i will let you know. thanks for sharing s Link to post Share on other sites
motorrob 15 Posted August 1, 2017 Author Report Share Posted August 1, 2017 Road and drag strip. Not experienced any binding which I was Suprised at. I have also wired in a switch so I can run front wheel drive or constant 50/50. So driving around town just use fwd. Going on a long drive this week so will run it 50/50 and see how effects fuel. Yeah let us know how you get on. Good to hear how people manage different ways of doing it. Link to post Share on other sites
ssaunders 199 Posted August 2, 2017 Report Share Posted August 2, 2017 9 hours ago, motorrob said: Road and drag strip. Not experienced any binding which I was Suprised at. I have also wired in a switch so I can run front wheel drive or constant 50/50. So driving around town just use fwd. Going on a long drive this week so will run it 50/50 and see how effects fuel. Yeah let us know how you get on. Good to hear how people manage different ways of doing it. Hi, thanks. dont burn the fuel for my benefit! switch wired to the precharge pump? i have read thats how others have done it. i have seen a few comments that it would wear clutch packs etc out but the cost of a rear diff 2nd hand is a couple of hundred now so cant see it being a major problem. i may drop you a line in a month or 2 to see how your getting on. cheers s Link to post Share on other sites
motorrob 15 Posted August 18, 2017 Author Report Share Posted August 18, 2017 Yeah switch to the pump. All is still fine,no issues. From Manchester to santapod I averaged 27mpg that's in constant 50/50 split. Turbo bolted on also so didn't think was too bad mpg. Link to post Share on other sites
mattvr6 133 Posted September 16, 2017 Report Share Posted September 16, 2017 In regards to wiring in a switch can this be done on/off while driving? On reason I ask is I think 0-60 times are quicker front drive when I've removed the fuse Link to post Share on other sites
motorrob 15 Posted September 17, 2017 Author Report Share Posted September 17, 2017 I tend not to change while driving. Just wait at traffic lights. Although I have done it. From 2wd to constant 50 works well. From constant to 2 wd it seems likes a little time for the oil to escape from the haldex unit (clutch) 30 seconds or so. I did try it on a ramp Link to post Share on other sites
Bungles 34 Posted November 26, 2017 Report Share Posted November 26, 2017 Just got my powertrack plug installed, just a heads up you will need more than 275ml of haldex fluid mine took took just over 2 tubes of oil Which was unexpected! Feels amazing from my first drive last night, more planted for sure feels like a big upgrade Link to post Share on other sites
mattvr6 133 Posted November 26, 2017 Report Share Posted November 26, 2017 Got any pics of the job? Sounds a lot that 2 tubes lol Link to post Share on other sites
motorrob 15 Posted November 26, 2017 Author Report Share Posted November 26, 2017 I only put one tube in mine. I think when I did the job the photos came out dark :/ Link to post Share on other sites
Bungles 34 Posted November 27, 2017 Report Share Posted November 27, 2017 When you do a service you only take out 275ml of oil can hold 450ml in total! No pics sorry got my trusted mechanic to do the job recommended to get a new gasket seal when doing the job! Took it for another drive last night and felt so planted highly recommend for other gen 1 haldex owners! motorrob 1 Link to post Share on other sites
Bungles 34 Posted November 29, 2017 Report Share Posted November 29, 2017 Link to post Share on other sites
Flylow 2 Posted February 1, 2018 Report Share Posted February 1, 2018 I use the haldex controller from HPA. Awesome Link to post Share on other sites
