hi all,just as i was setting off to the gti festival all my coolant was dumped over my girlfrinds feet in the passenger footwell as i went round a corner.the coolant seems to have leaked out behind the dashboard but before the engine bay.i'm going through a reservour of coolant every 1/2 mile! is it likely that just a hose has come loose or perished in there? the car runs absolutely fine. any ideas? thx
yeah- it would be a good idea unless you want the coolant to piss out all over you- its basically like a curcuit- ones feeding the fluid in - the other out. If you aint worried then just pull them off (when the engines cold obviously) Its not ideal to do this but if you need to get to work etc then itll get you by until your ready to take it apart and replace whatever is knackered
mines exactly the same , have joined the pipes together couple of weeks agoyou just dont get heat thats all the golf is an air blend system so has no valve its just a circuit of water , i just used a scrap heater pipe to join em together. bad news is its a big job to replace the matrix dash out and everything.
