donir32 0 Posted December 18, 2017 Report Share Posted December 18, 2017 Hey the other day i was down shift and noticed when i started letting go and engaging clutch on the downshift of 3rd to 2nd a "WHINDING NOISE" In addition it happens on when i depress the clutch on 3rd and engage around 3k rpm to 3500rpm it happens 80% of the time could it be the transmission on its way out or anything I can do to help my 10+ year old car. Looking to make the drive less rough also on 1st sometimes i hear a loud KNOCK as if whenever torque is stressed on the suspension/mounts/transmission makes a loud Knocking noise "in the past replacing AXLES has worked. (CAR WAS LOWERED now reset to stock suspension. 2 issues 1. DOWN SHIFT whinding noise 2. First Gear or whenever the car is pushed makes LOUD knocking noise Link to post Share on other sites
ssaunders 199 Posted January 4, 2018 Report Share Posted January 4, 2018 Hi, i have heard mostly good things about Redline MT\MTL for the transmission possibly worth a look. as for the knock is it a knock or a bang? i had a bang when giving it some beans and it was a dodgy engine mount, try it in gear with handbrake on to check movement or get a jack on the bottom to see how much it moves Link to post Share on other sites
