lev1710 0 Posted February 4, 2018 Report Share Posted February 4, 2018 Hi, Anyone have a link or guide to remove the rear subframe from a 4mo. I have the trailing arms off but just need to know if there is anything that's a must before dropping it i.e unseen sensor/connectors. Admin if this should be in the main technical section please move. Link to post Share on other sites
DerPanzerWagen 4 Posted February 5, 2018 Report Share Posted February 5, 2018 Simple: 1) Unbolt the drive shafts, prop & trailing arms from the subframe 2) The rear diff would have to be removed at the same time so remember to unplug. 3) ??????? 4) Subframe off! It's heavy but doesn't take that long to do. (Mine's be swapped out recently after 16 years of use.) Link to post Share on other sites
lev1710 0 Posted February 5, 2018 Author Report Share Posted February 5, 2018 Simple: 1) Unbolt the drive shafts, prop & trailing arms from the subframe 2) The rear diff would have to be removed at the same time so remember to unplug. 3) ???????4) Subframe off! It's heavy but doesn't take that long to do. (Mine's be swapped out recently after 16 years of use.)Thanks I had managed to find a thread with pics of the rear sub and I got the jist. It's taking me a long time as every bolt is bonded on and I am restricted for space so I need to get into angles and spaces that are a pain in the a**e. Cheers Link to post Share on other sites
motorrob 15 Posted March 31, 2018 Report Share Posted March 31, 2018 Just done mine with powerflex bushes. Wasn't to bad but a ramp definitely helped Link to post Share on other sites
