VR6 conversion
I converted my 1.6 to vr6 I didn't need to replace the pedal box you take the clutch cable out and the clutch master cylinder clips into the pedal/screws on the fire wall.
As for break lines, you will be able to use the hard lines but not the soft ones.
Feel free to ask any more.
I did mine about 8 years ago, you will need to get the master cylinder from a vr6 and then there is a plate that you can remove behind the clutch pedal where you will install the cyclinder.
How are you going about the conversation?
Have you got a Donna car?
