Recirculation valve on z engineering charger
Hey guys and girls just wondered if anyone is running a recirculation valve such as a 007p on a charged set up? I have a z engineering zr1 set up currently just wondering if I will benefit from one !
I have a 1.8t oem bosch one fitted to mine. I fitted at the same time as the supercharger, so I don't know what runs like without one!
  • 4 weeks later...
Im running a v9f with a bosch valve as well
Seems fine but i did do some reading and you can use the 007 or the forge splitter valve if you want more noise apparently
I thing the bosch ones are ok up to 8psi and then anything over your best off upgrading
