I've got my BBS et55 wheels that I want to take down to about ET 35 ? (does that sound ok?
I've been waiting since fucking APRIL for some arrive from Gwent VW and im getting pissed off, and I will need to get my arches rolled to fit when the wheels in situ.
Does anyone know where the best place to buy these from?
5 Stud PCD 100 wheels - I'd like bolt on adaptors as opposed to standard spacers and longer lugs.
Thanks.
Pete
i thought et 35 was standard ofset for most vw`s? if you have et 55 wheel then the outer part of the wheel will be closer to the inner wing (if that makes sense?) if you bolted it on right now, if you put a 20 mm spacer on your hub then that should bring the et down making it 35 and giving correct clearance on calipers etc, thats how i understand et ofset anyway.
