paul lane 0 Posted June 28, 2018 Report Share Posted June 28, 2018 hello there, i have a 97 mk 3 golf vr6 , it has been off the road for 3 years , it has always been started and run at least twice a week. recently it has started to have intermiten starting problems, it will start first and run fine but if you turn it off and try to start it again it won,t start , if i disconect the battery leave it for 15 mins then reconect the battery and try again the car will start but it will then do the same thing again ! any ideas ? Link to post Share on other sites
noggin 29 Posted June 28, 2018 Report Share Posted June 28, 2018 I had a similar issue and it was a faulty throttle position sensor. Could be that but then it could be a host of things. Link to post Share on other sites
VR6 Supercharged 104 Posted June 28, 2018 Report Share Posted June 28, 2018 5 hours ago, paul lane said: hello there, i have a 97 mk 3 golf vr6 , it has been off the road for 3 years , it has always been started and run at least twice a week. recently it has started to have intermiten starting problems, it will start first and run fine but if you turn it off and try to start it again it won,t start , if i disconect the battery leave it for 15 mins then reconect the battery and try again the car will start but it will then do the same thing again ! any ideas ? As noggin said it could be a host of things? If its been off the road 3 years and only started up and not driven? then things are not getting used, ie; sensors ect. Check the lambda sensor, also does it still retain the original factory immobiliser, as that could possibly factor into the problem.. Link to post Share on other sites
paul lane 0 Posted June 29, 2018 Author Report Share Posted June 29, 2018 as far as i know it has a factory immobiliser , the car came with two original standard keys Link to post Share on other sites
VR6 Supercharged 104 Posted July 9, 2018 Report Share Posted July 9, 2018 On 29/06/2018 at 12:05 PM, paul lane said: as far as i know it has a factory immobiliser , the car came with two original standard keys I feel its just going to be a case of process and elimination, which you already know. Good luck in sorting it... Link to post Share on other sites
markie 0 Posted July 11, 2018 Report Share Posted July 11, 2018 Hi thereI had a similar issue on my 96 vr6. It turned out to be the immobiliser which was wired to the fuel pump. You can check this by listening for the pump to engage on the first turn of the ignition key. In the end I joined the pump feed directly as the immobiliser was faulty. As mentioned though it could be a number of things eg fuel pump relay or your maf sensorHave you checked all the obvious stuff ?Mark Link to post Share on other sites
paul lane 0 Posted July 15, 2018 Author Report Share Posted July 15, 2018 hello again, does anyone know of a good mobile vw specialist for older cars in the bedfordshire area ? thanks Link to post Share on other sites
Phylo99 0 Posted July 20, 2019 Report Share Posted July 20, 2019 Hi did you resolve this issue? I have same problem with my 97 vr6 I’ve had new keys and chips and the thatcham alarm stripped out professional and it’s srill doing it please help Link to post Share on other sites
noggin 29 Posted July 21, 2019 Report Share Posted July 21, 2019 You could try replacing the throttle sensor and the crank position sensor. I don't think they're expensive. Link to post Share on other sites
Phylo99 0 Posted July 21, 2019 Report Share Posted July 21, 2019 Thanks have you had any experience with this problem? Where are they located Link to post Share on other sites
noggin 29 Posted July 25, 2019 Report Share Posted July 25, 2019 On 21/07/2019 at 9:41 PM, Phylo99 said: Thanks have you had any experience with this problem? Where are they located Yes mate. I got stranded a couple of times when the car refused to start. I'd leave it half hour and it would fire up. My mate fixed it for me so I don't know where they're located. I'm sure youtube or google have the answer. Link to post Share on other sites
