Steveo 0 Posted July 14, 2005 Report Share Posted July 14, 2005 I've never owned a VR6 before or even spent this much on a car, hence why I get a little paranoid about noises. So my questions are,Is it normal to hear the water bubbling after switching the engine off? Even during normal driving I can hear it inside the car.Also is it normal for there to be vibrating in the coil after the engine is switched off, its the round black coil at the back right top of the engine. Its almost like theres a fan inside going round. It stops after a while but I need my mind putting a ease.I probably sound like a right tit, but I want to look aftr this one so thanks for any helpSteve Link to post Share on other sites
mightyvr6 0 Posted July 14, 2005 Report Share Posted July 14, 2005 It's not normal imo. The noise your hearing could be the aux water pump rather than the coil which is located in the place you describe and can get noisy with age. Does the car run hot or overheat? Link to post Share on other sites
Steveo 0 Posted July 14, 2005 Author Report Share Posted July 14, 2005 No thats the one thing I've been keeping an eye on. Drove the car for more than two hours the other night temp stayed at normal, and oil temp never rose above 94. Ill take some pics over the weekend and point to the part in question. Fingers crossed shell get me to Devon okay tomorrow. !sad Link to post Share on other sites
mightyvr6 0 Posted July 14, 2005 Report Share Posted July 14, 2005 Hopefully it's nothing major. Probably the aux water pump but some pics should clarify that. Has any work been done on the coolant system recently? I was thinking there could be an airlock in the system - is the water bubbling in the expansion tank? Link to post Share on other sites
Nerih 0 Posted July 15, 2005 Report Share Posted July 15, 2005 to get rid of an airlock in my mk2, i used to run the car from cold until the system had fully opened (the top pipe gets hot) with the cap off of my expansion bottle + i used to squeeze the top pipe (going in to rad) a bit every now and then.remember water doesnt boil until it gets to 100 degrees and if you've got a decent anti freeze concentration, it shouldnt bubble!!!! so i'd be a bit cautious to what it actually is, it could be water rushing around inside an airlock in your heater matrix, check if you're heater blows hot air... Link to post Share on other sites
Steveo 0 Posted July 15, 2005 Author Report Share Posted July 15, 2005 Guys thank you very much for your help. Im glad you said that because as soon as I told a work colleague this morning thats exactly what they said. They think theres a airlock in the heater matrix. How you rectify this I do not know, GARAGE!! lol Link to post Share on other sites
badboyV6 4 Posted July 15, 2005 Report Share Posted July 15, 2005 When you turn the engine off yuo will hear a trickling noise- thats the auxillary water pump doing its stuff- mine kneckered and soesnt come on at all... Need to get it sorted asap... However ti must be making a right racket to hear it when driving so id go with air lock too. the vibrating noise from the black socket- feck knows- i know what you mean though- same thing used to happen with my old indian red VR (which was a minter and never let me down) i think its probably something to do with the pump... Link to post Share on other sites
Nerih 0 Posted July 15, 2005 Report Share Posted July 15, 2005 your aux pump should make a noise, no noise = bad.get your matrix sorted out by doing what i said, or cycling the coolant in the system. Link to post Share on other sites
shail 0 Posted July 15, 2005 Report Share Posted July 15, 2005 I got this when changing the coolant on mine - it was just an air lock. One thing to remember - to get the hot water running thru all your system (inc the heater matrix) be sure to have your heater temperature dial set to HOT. I got the air out by leaving the cap off the exp tank and running till fans came on, whilst 'burping' the pipes by squeezing them, including the 2 that go into the heater matrix. Link to post Share on other sites
Steveo 0 Posted July 15, 2005 Author Report Share Posted July 15, 2005 Brill I'll give it ago over the weekend. Another quickie whats the difference between a Syncro and a normal VR6.Thanks again for all your help. Link to post Share on other sites
stockers 1 Posted July 15, 2005 Report Share Posted July 15, 2005 syncro is 4x4 and pretty hard to come by ,(think they are all left hand drive) :? Link to post Share on other sites
Nerih 0 Posted July 16, 2005 Report Share Posted July 16, 2005 syncro has 4 wheel drive. Link to post Share on other sites
badboyV6 4 Posted July 16, 2005 Report Share Posted July 16, 2005 certainly does- uses a viscous coupling on the mk3 - and all all are 2.9. They are all left hand drive too as they never sold them over in the uk, shame. Link to post Share on other sites
Steveo 0 Posted July 17, 2005 Author Report Share Posted July 17, 2005 Cool thanks for that guys. Link to post Share on other sites
Steveo 0 Posted July 20, 2005 Author Report Share Posted July 20, 2005 Thanks I'll give it a go, if dont suceed I'll take it to the garage. Link to post Share on other sites
Nerih 0 Posted July 20, 2005 Report Share Posted July 20, 2005 if you want a syncro go buy a raylle or r32 or v64motion...mk3 syncro is just too hard to find. Link to post Share on other sites
purple highline monster 0 Posted July 20, 2005 Report Share Posted July 20, 2005 4 wheel drive!! on the continent i have seen a few knocking around for sale Link to post Share on other sites
Steveo 0 Posted July 20, 2005 Author Report Share Posted July 20, 2005 No no I dont want one, just didnt know what it was. No way am I parting with my VR. How often do people meet up in the South East area here. It would be good to look at other peoples and pinch some ideas. Link to post Share on other sites
purple highline monster 0 Posted July 21, 2005 Report Share Posted July 21, 2005 i think there is a meet every second thursday at wrotham off the m26 but as yet i havnt been due to work commitments, club gti used to meet at the hotel at brands hatch which was good as they have a nice car park!! Link to post Share on other sites
Steveo 0 Posted July 21, 2005 Author Report Share Posted July 21, 2005 !amazed Yikes thats miles away, at least a 2 1/2 hour drive. Ill wait till a main event or some thing closer to home. Cheers though. Link to post Share on other sites
Pittuf 0 Posted July 21, 2005 Report Share Posted July 21, 2005 Junction 29 meet up the 3rd sunday of every month at The Halfway House pub on the A127 just off junction 29 of the M25.In fact there is a meet this weekend iirc Link to post Share on other sites
