NathR32T 4 Posted August 16, 2019 Report Share Posted August 16, 2019 hi all new to the forum , had a r32 for a long time now about 10 years ish .... anyway list of current engine mods / recent work: R32 HGP TURBO GT35 with custom housings VAG 630cc injectors (4 bar) 8:5:1 Compression Short Runner Intake Exhaust Manifolds with Lambda Ports Down pipe with internal Wastegate HGP map Custom 3" Lucifer exhaust with VACS custom decat Running approx 20 psi Approx 520 bhp 490 ftlbs Sachs Race Single Mass Flywheel , sintered paddle disc Secondary Fuel Pump Rear 312mm Discs with standard calliper Front brakes Porsche 6 Pots with original 334mm Mtec discs ( in progress) Colour MFA dash (built by @ard_technik ) Newsouth Oil Pressure Gauge , offset column pod HPA Touch Motion controller 18" BBS CK alloys Custom Headlight 'US' Spec with full LED conversion from standard xenon Pioneer music thingy with Custom Gear Knob... Poly bushed and on collies i'm also after some advice on Gaz coilovers GHA335 ? any good ? cheers guys Tyler89, VR6 Supercharged and noggin 3 Link to post Share on other sites
VR6 Supercharged 104 Posted August 16, 2019 Report Share Posted August 16, 2019 Outstanding sir, simply outstanding. Currently on the look out for an R32 (Already own a Supercharged MK3 VR6) which I will be keeping in standard trim... Tyler89 and NathR32T 2 Link to post Share on other sites
Tyler89 7 Posted August 16, 2019 Report Share Posted August 16, 2019 hi all new to the forum , had a r32 for a long time now about 10 years ish .... anyway list of current engine mods / recent work: R32 HGP TURBO GT35 with custom housings VAG 630cc injectors (4 bar) 8:5:1 Compression Short Runner Intake Exhaust Manifolds with Lambda Ports Down pipe with internal Wastegate HGP map Custom 3" Lucifer exhaust with VACS custom decat Running approx 20 psi Approx 520 bhp 490 ftlbs Sachs Race Single Mass Flywheel , sintered paddle disc Secondary Fuel Pump Rear 312mm Discs with standard calliper Front brakes Porsche 6 Pots with original 334mm Mtec discs ( in progress) Colour MFA dash (built by @ard_technik ) Newsouth Oil Pressure Gauge , offset column pod HPA Touch Motion controller 18" BBS CK alloys Custom Headlight 'US' Spec with full LED conversion from standard xenon Pioneer music thingy with Custom Gear Knob... Poly bushed and on collies i'm also after some advice on Gaz coilovers GHA335 ? any good ? cheers guysVery nice car man nice list of mods as well very clean NathR32T and VR6 Supercharged 2 Link to post Share on other sites
NathR32T 4 Posted August 16, 2019 Author Report Share Posted August 16, 2019 Thanks guys ! Had a scout around the forum seems kinda active still which is bonus ! Looking forward to getting the Porsche 6 pots on and update the coilovers before a trip to Austria and of course the ring and the Mecca for VW of course also VR6 Supercharged 1 Link to post Share on other sites
rackwarv 0 Posted October 2, 2019 Report Share Posted October 2, 2019 Nice setup! Link to post Share on other sites
