qgoose 0 Posted July 26, 2005 Report Share Posted July 26, 2005 Hi AllMy golf has an exceedingly rotten tailgate. I have sourced an appropriate replacement part to replace it. My query for anyone who might have done this swap before is how to route the electrics and air (for the central locking) and water (for windscreen wipers) pipes through the hatch in the channels at the side of the glass.Has anyone done this who might be able to offer advice. My best idea at the moment is to run some lengths of string through when removing the old cables and pull the ends back through using the string.Thanks in advanceSi (V)W Link to post Share on other sites
antera309 3 Posted July 26, 2005 Report Share Posted July 26, 2005 I did this job on my old VR, I used one of these: Link to post Share on other sites
qgoose 0 Posted July 26, 2005 Author Report Share Posted July 26, 2005 Ahhhh! What a good idea. I assume that you inserted it through the various drainage holes and then just worked all the cables round to the desired positions. Many thanks for your help. !lol BTW, The picture you have in the Authors box is of a cabriolet. Have you dropped a VR6 lump into it? 8) Si (V)W Link to post Share on other sites
jezmoz 0 Posted August 1, 2005 Report Share Posted August 1, 2005 in body shops they use stiff but bendy wire, i have seen them use it Link to post Share on other sites
dusty_mauve 0 Posted August 3, 2005 Report Share Posted August 3, 2005 I used a wire coat hanger wrapped in insulation tape with a little hook on the end to pull the cables thru Link to post Share on other sites
