VR6Andy 0 Posted April 13, 2004 Report Share Posted April 13, 2004 I have checked out several threads relating to oil temp, I changs my oil every 5K with semi-synthetic and recently noticed that while driving at a steady 80mph the oil temp can touch 114 degrees no problems, if I thrashed it i am sure it could get to 120. I have been told this is an acceptable temp as the warmer the oil the better the lubrication and thus quality of oil.????What do you think.To add to this for the past 18 months the water temp has not moved above 90 which is central, it has now started to raise on runs to about 100. IS MY VR TRYING TO TELL ME SOMETHING???? Link to post Share on other sites
eViL 0 Posted April 13, 2004 Report Share Posted April 13, 2004 cruising at 80mph would give me an average Oil temperature of 84 degrees and water temp of around 75-80.I'd say you were running a little warm. Wouldn't worry too much, but to be safe check your coolant, oil and check that all your temperature sensors are working correctly.Always better to be safe than sorry. I've learnt the hard way..I only ever had an oil temperature of over 120 once and that was after a blast from Bognor Regis at 3 in the morning at an average speed of around 120mph all the way. (emergency)But I'm no expert. Link to post Share on other sites
jcorallo 0 Posted April 13, 2004 Report Share Posted April 13, 2004 yes - 114 is a bad sign. It should be hovering around 98 to 104ish.Its prob a stuck closed thermostat. Get it sorted or you'll blow the engine or other bits.Jules Link to post Share on other sites
speedo 0 Posted April 13, 2004 Report Share Posted April 13, 2004 Yer stat and probably pump problems.. Mines done 103k and had 3 pumps in its life (so far!!)There is also a oil cooler on ebay at moment... well worth a look Link to post Share on other sites
blackburnvr6 0 Posted April 14, 2004 Report Share Posted April 14, 2004 just a quick one going to change the water and coolent in mine what is the best mix to put in and best product?? the max line on the water bottle should that be the max when cold or when hot?? Link to post Share on other sites
binliner 0 Posted April 14, 2004 Report Share Posted April 14, 2004 I use the pink VW stuff (sorry dont know what its called) and the max line is cold Link to post Share on other sites
FishWick 21 Posted April 14, 2004 Report Share Posted April 14, 2004 G12+ from the dealer is the stuff to use. A 70/30 G12+ to water blend is fine for the UK. Too much G12 reduces the water's ability to absorb heat.Agreed with the other guys, 114 at a steady 80 is too high. A new stat and fresh coolant should reduce it to more acceptable levels.Kev Link to post Share on other sites
mightyvr6 0 Posted April 14, 2004 Report Share Posted April 14, 2004 use de-ionised water. Link to post Share on other sites
blackburnvr6 0 Posted April 15, 2004 Report Share Posted April 15, 2004 just another one is there a special way of draining the water out or is it a case of disconeting apipe Link to post Share on other sites
mightyvr6 0 Posted April 15, 2004 Report Share Posted April 15, 2004 yes there's a drain plug. Look below the inlet manifold on the front of the engine block and you should see a long black plastic coolant pipe. It has a drain plug about half-way down which is accessible from underneath. Unscrew it using a coin or screwdriver. Undo the bottom rad hose too. Link to post Share on other sites
blackburnvr6 0 Posted April 15, 2004 Report Share Posted April 15, 2004 cheers for that do i need to flush it and were can i get de-ionised water from Link to post Share on other sites
mightyvr6 0 Posted April 15, 2004 Report Share Posted April 15, 2004 You can flush it through with a hose. Halfords sell de-ionised water. They call it "battery top up water". Link to post Share on other sites
VR6Andy 0 Posted May 19, 2004 Author Report Share Posted May 19, 2004 I had my new stat and coolant fitted today, also oil and filter change with Synta sliver.On the 40 mile run home at the steady 80mph and the water temp did'nt budge above 90 and the oil topped out at 102 and dropped, off the m-way to 90, looks like I've cured the overheating probs Link to post Share on other sites
