matrix 0 Posted August 21, 2005 Report Share Posted August 21, 2005 reading through some of the history it has had relacement sensors b4 ive heard they get dirty what do they look like where r they.thxphil Link to post Share on other sites
J5KE F 0 Posted August 21, 2005 Report Share Posted August 21, 2005 I think, theyre down by the brake disc. look for a cable running near the brake line & ABS Sensoors should be on the end!I think the mk3 in general has problems with ABS lights. Both my missus' mk3's had faults and needed sensors, mine however just requires switching of and back on to reset on the odd occasion as the fault is intermittent. Link to post Share on other sites
matrix 0 Posted August 21, 2005 Author Report Share Posted August 21, 2005 just went for a drive the light went out then came back on again? Link to post Share on other sites
J5KE F 0 Posted August 21, 2005 Report Share Posted August 21, 2005 Sounds like sensor on its way out?mine cuts in and out every 3 weeks or so, and i put that down to the pads i use & heavy braking! someone'll give you the answer when the forum pics up durin the week. Link to post Share on other sites
matrix 0 Posted August 21, 2005 Author Report Share Posted August 21, 2005 ive heard the abs controll module can cause this prob aswell Link to post Share on other sites
